Differences of studs vs. Timeserts
Results 1 to 5 of 5
Northstar Engines and System Technical Discussion Discussion, Differences of studs vs. Timeserts in Cadillac Engine Discussion; have a 93 Allante that needs the HG fix. Can someone give me the differences in using studs (like N* ...
    wcoates is offline Cadillac Owners Fanatic
    Automobile(s): 1989 Red Allante,
    Nov 2005
    Canfield Ohio
    313
    have a 93 Allante that needs the HG fix. Can someone give me the differences in using studs (like N* Performance) vs timeserts. Which is preferable
    and why. Thanks
    vincentm's Avatar
    vincentm is offline Cadillac Owners Connoisseur
    Automobile(s): 1997 Cadillac Eldorado ETC
    Aug 2010
    Kennewick WA
    38
    4,848
    Re: Differences of studs vs. Timeserts
    Timesert a single cylindrical threaded insert that goes into the block after the bolt hole has been re-tapped. you insert the timesert then the head bolt
    Stud is an all in one stud with a large bite into the block, you still retap the bolt hole to accomodate it, slide the head on and torque down via a nut that screws onto the top of the stud.
    http://www.northstarperformance.com/sgstuds.php
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    57,174
    Four ways to do the block thread repair job:
    Jake's (Northstar Performance) studs, washers and nuts.
    BigSerts - the follow-on to Timesert - and stock head bolts.
    Norm's Inserts (NS300) with stock head bolts.
    Norm's Inserts (NS300) with ARP Volkswagen studs, washers and nuts.
    69
    82,396
    Inserts get torqued in just like head bolts and put pressure on the aluminum threads as they are installed, though maybe not as much as the bolts. Jake's studs are installed finger tight so there is no galling of the threads. All the clamping pressure is on the top stud (steel) thread. In theory it is better. In reality I don't know if it makes all that much difference or not. Personally I see no benefit to using inserts and (ARP) studs unless you plan on removing the heads multiple times.
    97EldoCoupe's Avatar
    97EldoCoupe is offline Owner of Northstar Performance
    Automobile(s): 97 ETC x2, 04 GXP, 04 STS x2, 97 ESC, 99 Deville, 05 SRX
    Mar 2007
    The Great White North
    31
    2,600
    Whatever you choose, studs are becoming readily available again. I have a stack of orders to catch up to and a large # have shipped this week. The remainder is going next week. I will post an update under the "Wish you the best of Luck Jake" thread-
  8. Remove Advertisements
