PCM/EBTCM Pin Diagram, 2001 SLS
Results 1 to 4 of 4
Northstar Engines and System Technical Discussion Discussion, PCM/EBTCM Pin Diagram, 2001 SLS in Cadillac Engine Discussion; Hello all, I have searched, and have not found, pin diagrams for both the PCM and EBTCM for my 2001 ...
    Ekindler0584 is offline Cadillac Owners Member
    Automobile(s): 2001 SLS (Diamond White)
    Dec 2005
    Columbus, OH
    32
    81
    Hello all,
    I have searched, and have not found, pin diagrams for both the PCM and EBTCM for my 2001 Seville SLS. Could someone please assist me?
    Thank You,
    Ed Kindler
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    56,237
    Re: PCM/EBTCM Pin Diagram, 2001 SLS
    ternstes is offline Cadillac Owners Fanatic
    Automobile(s): 2011 CTS V, 2007 SRX V8, 2005 CTS 3.6L, 2000 STS, 1999 STS
    Nov 2008
    SW Ohio
    36
    394
    Here you go, what trouble are you having?
    Dec 2005
    Columbus, OH
    32
    81
    Yes Sub, I have had this car for nearly 6 years, and I still have not subscribed to AllData!
    And to Ternstes, thank you very much for posting! As far as the issue, I am getting "No ABS Data" along with P1571. I had rebuilt (or more accurately resealed) the engine over the summer due to a combination of failed head gaskets and a moderate oil leak on the bottom end. In doing sa, I believe I may have damaged the wiring harness between the PCM and EBTCM. I need the pin diagram so I can, as a first step to resolve the issue, go through and ohm out the wires. Thanks again!
  7. Remove Advertisements
