Please help: 1996 deville hard starting ?
Page 1 of 2 12 LastLast
Results 1 to 15 of 16
Northstar Engines and System Technical Discussion Discussion, Please help: 1996 deville hard starting ? in Cadillac Engine Discussion; Hi guys, I have a 1996 deville with 98k miles that seems to have a periodic long starting issue. Doesnt ...
    VIPERRACING is offline Cadillac Owners Member
    Automobile(s): Cadillac
    Mar 2008
    58
    Hi guys, I have a 1996 deville with 98k miles that seems to have a periodic long starting issue. Doesnt matter if its cold or hot. It happens about every 4th or 5th cycle and in between those cycles it just starts up with no issues. Had the battery checked and they said it was bad so I changed it and still have the problem. Car also has a new fuel pump but has been reported to having this problem before the new pump went in. Dealership cant figure it out. Thought that maybe the fuel regulator was going bad but pulled the vacuum line to it and it was dry. I cant believe that Im the only one with this issue. Any help is greatfully appreciated. Thanks ahead of time, Tony.
    maeng9981's Avatar
    Mar 2009
    Dallas, TX
    25
    3,993
    Re: Please help: 1996 deville hard starting ?
    Have you cleaned the throttle body?
    Mar 2008
    58
    No I havent. If it was dirty wouldnt that make the car hard to start all time and not periodicly? The car idles very smooth and never stalls.
    maeng9981's Avatar
    Mar 2009
    Dallas, TX
    25
    3,993
    My Deville used to fail at starting once in a while. Had to retry several times, it wouldn't start unless I pushed the gas pedal a little bit. Other times it started just like normal, turn the key and it starts. Then after a long time the gas pedal started sticking. Cleaned the TB, and all is gone.
    Mar 2008
    58
    Yes that is exactly what mine is doing minus the sticky pedal. I just thought that it might be a fuel issue or sensor issue causing the problem. Im not sure if the dealership replaced the fuel filter when they did the pump but I do know that this has been a issue with this car for a long time now after having the dealership pull the records for the car. What(how) did you clean the throttle bottle with? Thanks
    maeng9981's Avatar
    Mar 2009
    Dallas, TX
    25
    3,993
    People replace the fuel filter as a precaution but I never heard of any problems caused by fuel filters other than rusted out units.
    To clean the TB: remove the intake ducting, remove the MAF sensor and screen unit. Open the throttle body butterfly by either pushing the accelerator pedal with a heavy object or get someone to push it down while you are cleaning. Spray a throttle body cleaner on the buildup on the butterfly and the throttle body itself; use an old toothbrush. There is a shiny side under all the buildup. Clean it through, try to remove buildup as much as possible. Don't let any unwanted objects like spray straw get into the intake. Reassemble everything, and test the car.
    69
    82,269
    FYI, there is a tutorial in the Tech Tips section on TB cleaning with pictures.
    Mar 2008
    58
    Guys, I cleaned the tb & maf and Im still having the same issue. Anything else that could be causing this issue?
    89falcon is offline Cadillac Owners Fanatic
    Automobile(s): my wife crazy, 1997 STS, 2004 CTS
    Apr 2011
    188
    Quote Originally Posted by VIPERRACING View Post
    Small headgasket leak.....
    run a block test.
    69
    82,269
    No DTC's I presume?
    Mar 2008
    58
    Ive already been through the hg issue with my other cadillac and its not that. Car starts up and runs smoothly but sometimes its just hard to start exactly as stated in post #4. Im actually opening the tb slightly via foot pedal upon start up and so far its been firing up but Im going to continue this method for a day or so to make sure it does start up ever time. I will keep you all posted. Also do you guys know what the voltage is supposed to be on these cars? Mine ranges anywhere from 11v to 14v but never the same consistence. Also has anyone had any luck with the monroe 90008 & 90009 shock conversion? Thanks again for all the help.
    iflipcars's Avatar
    iflipcars is offline Cadillac Owners Member
    Automobile(s): 98 Deville D'Elegance, VIN Y
    Nov 2011
    Chicago, SW suburbs
    46
    60
    When the throttle is closed, air is allowed into the engine via the IAC (Idle Air Control Valve). If it is sticking shut on occasion, its possible that it is your problem.
    See this post here and clean the IAC also.
    Apr 2011
    188
    I do find that my STS can be "finicky" about battery voltage.....try hooking it to a charger when you start it.....just to troubleshoot.
  16. #14
    Mar 2008
    58
    Ill try cleaning the iac and let you knolw how it turns out. I thought that the iac only controlled idle and since I never had a problem with the car idling or stalling I never thought that would be the problem. Thanks
  17. #15
    69
    82,269
    Be sure to clean the TB first. It is more likely the problem. If that doesn't help, then do the IAC valve.
    Voltage should be around 14v with the engine running.
  18. Remove Advertisements
