1997 Deville Transmission Service
Results 1 to 3 of 3
Northstar Engines and System Technical Discussion Discussion, 1997 Deville Transmission Service in Cadillac Engine Discussion; I decided to service my 1997 Deville transmission and do not see the "Hidden drain plug". I have a car ...
    gtmick00 is offline Cadillac Owners Member
    8
    I decided to service my 1997 Deville transmission and do not see the "Hidden drain plug". I have a car lift and have plain view of the bottom with the pan removed and I do not see it. Any help yould be greatly appreciated. Also should I replace the pan gasket, it is still in one piece.
    BeelzeBob's Avatar
    Dec 2002
    Fort Lauderdale, Florida
    52
    9,577
    Re: 1997 Deville Transmission Service
    Look at the area of the trans inside the pan under the side cover. It is up at the torque converter end of the trans..... It is just a bolt head that isn't holding anything down.....
    If the pan gasket is in good shape it can be reused.
    Be sure and clean the oil pickup screens of any debris. That keeps any "chunks" from being picked up and transferred to the side cover oil storage area where the pickup filter is located.
    8
    Thank's bbob, i found it after your reply. I was suprised it was so small, I was looking for a larger plug.
    Thanks Again,
    Gerald
