Replacing a TPS in a 99 Deville?
Results 1 to 9 of 9
Northstar Engines and System Technical Discussion Discussion, Replacing a TPS in a 99 Deville? in Cadillac Engine Discussion; I am getting codes P0122 and P1122 P0122 Code - Throttle Position Sensor/Switch A Circuit Low Input P1122 Throttle Position ...
    arctic_man's Avatar
    arctic_man is offline Cadillac Owners Fanatic
    Automobile(s): 2004 Deville
    Jun 2008
    The Sticks, MN
    27
    264
    P1122 Throttle Position (TP) Sensor Circuit Intermittent Low Voltage
    I figured I can replace the TPS first, as I am also showing the usual signs - car drives itself, high RPMs in park. etc
    I just have one question... How do I get to the bottom screw? I really do not want to put coolant all over my floor... again... I have found a few posts to changing one out, but no one said what they used? Is there a special tool I need besides the torx bit?
    Aside from that, I just need to do a TPS relearn, correct? I heard of two different procedures, one is to just unhook the battery for 10 odd minutes, hook the battery up, and then start the car and drive it, and the other is much more complicated than that. Which one is the one that I should use?
    arctic_man's Avatar
    Jun 2008
    The Sticks, MN
    27
    264
    Re: Replacing a TPS in a 99 Deville?
    Any suggestions
    68
    81,917
    The TPS is on the side of the TB. No coolant involved and the mounting bolts (or screws) should be readily accessible. Not sure, but it might need to be adjusted when installed.
    MoistCabbage's Avatar
    Sep 2010
    East Boston MA.
    29
    26,325
    The relearn will eventually happen on it's own, disconnecting the battery is just a way to speed up the process. The TPS on your car has no adjustment.
    arctic_man's Avatar
    Jun 2008
    The Sticks, MN
    27
    264
    The bottom of the TPS is blocked by the dog bone brace, and the brace has a bolt that is tied in with a tube that runs underneath it. Unless there is a tool that will allow me to get at the screw at an angle, I am stuck either removing the brace, and putting coolant on my floor, or removing the TB. I will go ahead and take pictures tomorrow for a reference, I actually just got back from a trip and have the weekend to work on it
    arctic_man's Avatar
    Jun 2008
    The Sticks, MN
    27
    264
    Attached is where the bottom screw is. Allen wrenches appear to be too long. The other picture is showing the tubing that connects to the bottom of the dog bone bracket. I assume coolant runs through it. If I go this route I will remove the bracket and end up putting coolant on my floor. Unless there is a different tool that will work, I either need to remote the TB or remove the dog bone and bracket.
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    55,891
    The tube is the purge line from/to the coolant reservoir. On later models that do not have dogbones that hollow bolt/nipple is also one of the attaching points for an engine lift strap.
    arctic_man's Avatar
    Jun 2008
    The Sticks, MN
    27
    264
    Is it safe to remove that tube without the car running?
    Feb 2006
    55,891
    Without the engine on you'll get a trickle of coolant out of the hollow bolt/nipple. DO NOT let any coolant drip down onto the EBTCM which is on the frame flat just rearward of the driver's end radiator tank. Lots of brake lines attached, as well as a sensitive multi-pin electrical connector.
    In order to test flow, you remove the line from the reservoir top side - hold the end in the open filler neck - it's a small steady stream which bleeds off air and gas at a cooling system high point - but do it with the engine cold ! Pull it off hot and you uncork a 16 psi snake..........use an assistant on the ignition key.
  12. Remove Advertisements
