1994 cadillac seville Spark plug change
Results 1 to 7 of 7
Northstar Engines and System Technical Discussion Discussion, 1994 cadillac seville Spark plug change in Cadillac Engine Discussion; So i'm about to change the spark plugs on my 1994 cadillac seville. I know there's a tech tips section ...
    nash8 is offline Cadillac Owners Member
    Jan 2006
    56
    So i'm about to change the spark plugs on my 1994 cadillac seville. I know there's a tech tips section that has a detailed instructions, but I can't seem to find it. Can anyone post a link to this specific page, or give idiot proof instructions how to get there?
    tateos's Avatar
    tateos is offline Cadillac Owners Connoisseur
    Automobile(s): 1997 ETC (GAVE TO STEPSON 2011), 2000 DTS (RIP)
    Jul 2007
    FOUNTAIN HILLS, AZ
    60
    1,704
    Re: 1994 cadillac seville Spark plug change
    Nothing much to post - pull the plug wire, remove the old plug, re-install the new plug. I use a little no seize on the threads. I think you may find it's worth the time invested to unbolt the ignition module and coil pack off the right bank - it will give you some more access to those plugs
    89falcon is offline Cadillac Owners Fanatic
    Automobile(s): my wife crazy, 1997 STS, 2004 CTS
    Apr 2011
    188
    Quote Originally Posted by tateos View Post
    DEFINITELY use "anti-seize" on the threads, and also get some "dielectric grease" to put on the inside of the spark plug wire boots.......it will help prevent "arcing"
    68
    81,913
    Good advice, but be advised that there is a mounting bolt on the back side of the ICM that you'll need to use the Braille method to remove and reinstall.
    Jan 2006
    56
    Aight cool, I didn't think there was anything more to it than that. Just figured I would double check so I didn't run into any suprises.
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    55,875
    Use this to make sure all the plug wires are connected correctly - it's important - Google "waste spark ignition" to find out why.
    Jan 2006
    56
    Cool, thanks sub, I found that diagram the other day in another thread, but I didn't save the link. Saved me some time searching for it again.
  10. Remove Advertisements
