Curious. . .crankshaft position sensors, are they reversable?
Results 1 to 5 of 5
Northstar Engines and System Technical Discussion Discussion, Curious. . .crankshaft position sensors, are they reversable? in Cadillac Engine Discussion; Does it matter which ckp harness gets plugged into which ckp? If so which should be the top and which ...
    miwise is offline Cadillac Owners Fanatic
    Automobile(s): 1999 Cadillac Seville STS
    Jul 2010
    Lafayette, Louisiana, United S
    39
    448
    Does it matter which ckp harness gets plugged into which ckp? If so which should be the top and which should be on bottom? These are the grey and black harness plugs i refer to.
    Jul 2010
    39
    448
    Re: Curious. . .crankshaft position sensors, are they reversable?
    Nevermind. I looked up the diagrams. It looks like they are keyed so I don't believe I could have reversed them when plugging them back in.
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    55,850
    Quote Originally Posted by miwise View Post
    ^^^ Yes.
    Jul 2010
    39
    448
    thanks!
    Jul 2010
    39
    448
    Well, after calling dealerships and being turned away b/c my car was too old, I found someone with a tech 2. . .the auto shop at my place of employment. Thank goodness they buy GM. Was able to complete the relearn procedure. I will drive it a while and see if that helps it. Of course now I have other gremlins I'm chasing. Drivers a/c actuator and recirc air door actuator both messed up. I've figured out how to fix that as well. Who needs a mechanic? LOL
  8. Remove Advertisements
