Taking Pre-Orders for bottom end stud kits-
Results 1 to 14 of 14
Northstar Engines and System Technical Discussion Discussion, Taking Pre-Orders for bottom end stud kits- in Cadillac Engine Discussion; The standard size bottom end stud kit has now been designed. Benefits: -more accurate torque -studs are fully engaged in ...
    97EldoCoupe's Avatar
    97EldoCoupe is offline Owner of Northstar Performance
    Automobile(s): 97 ETC x2, 04 GXP, 04 STS x2, 97 ESC, 99 Deville, 05 SRX
    Mar 2007
    The Great White North
    31
    2,600
    Benefits:
    -studs are fully engaged in the aluminum block threads prior to the torque process
    -less chance of threads stripping out (by far)
    -less chance of oil pressure loss (oil flows past the shaft of 12 of the main bolts/studs, if one is not properly torqued, your engine will wear out)
    -proper claming force on the bottom end will promote better bearing break-in (as opposed to loose bolts or uneven clamping pressure)
    -guaranteed not to snap (as the original factory bolts often do)
    -oversized repair studs (patent pending) will be available as well in full sets or custom quantity mix (repair only the holes that actually are stripped, yet still have the whole bottom end studded)
    These are metric roll-threaded studs that will handle way more clamp load than the factory original bolts. Remember- the way the bottom end is designed, bearing clearance is determined by the factory machining of the block. As long as the mating surfaces are clean between the block halves, and you torque the perimeter bolts in sequence PRIOR to main stud torque, a bit extra clamp force than factory will not distort the castings or change bearing clearance. Details will be released on torque specs, but so far I believe we will be going with:
    -studs screwed hand tight in the block
    -nuts torqued to 45 ft. lbs. (as this thread ages, please check our website for proper/current torque specs)
    An added feature to promote proper oil distribution (instead of any possible bypass by the flange nut) is an O-Ring seal on the nut. This combined with thread locker/sealant tape on the stud will eliminate any possible oil-bypass. In other words, we need to do everything possible to keep pressurized oil up where it belongs: around the bearings and moving parts- not dripping past the bolts back into the oil pan.
    I expect to ship without any exception by August 30th/2011 and guarantee by September 8, 2011. For one forum member it will be much quicker because he was the first one to speak up and ask for the kit.
    The oversized studs and/or kit will be available soon for permanent, problem free thread repairs.
    Here's a photo of the stud.
    Pricing for pre-orders is set at $155 per set + shipping costs (probably about $20 to most states), + taxes for Canadian customers
    Pricing is subject to change after the kit is fully available. Priority goes as follows: First come, first served. Email info@northstarperformance.com with subject "MAIN STUDS" in the subject line. Thank you all!
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    57,148
    Re: Taking Pre-Orders for bottom end stud kits-
    Jake, from an old engine builder: $155 is far, far too low for 20 specially made studs, nuts, washers, O-rings. You won't even cover your labor, much less materials.
    Mar 2007
    31
    2,600
    Thank you Jim- I likely will not be able to keep my price of $155 but I am still working to cover the cost of getting that CNC machine in the shop to produce everything in-house. I'm currently willing to sell at cost if need be (pre-orders a month ahead is money up front that I can use as capital to finish paying for the Miyano.) Where are decent banks, where are leasing companies- when you need them. Money is refundable if I for some reason cannot deliver as promised. But if the customers can wait a few weeks and are willing to trust me, it is a savings for them, and it helps me get what I've needed since the beginning.
    Mar 2007
    31
    2,600
    I've seen CNC machining in action and NOTHING beats the speed and precision.
    ternstes is offline Cadillac Owners Fanatic
    Automobile(s): 2011 CTS V, 2007 SRX V8, 2005 CTS 3.6L, 2000 STS, 1999 STS
    Nov 2008
    SW Ohio
    36
    393
    Looks great, Jake!
    ThumperPup's Avatar
    ThumperPup is offline Cadillac Owners Master
    Automobile(s): not anymore 2007 Lexus ES350
    Mar 2009
    Murray/ Snowbird Utah
    37
    7,688
    ok um im confused here so these studs are for the bottom end do you mean for the oil pan ? or are these for the half shaft ? since im not all that experience and im not a mehcanic don't know what im looking at exactly but curious what are the studs for ? are those what hold the Oil pan on on the bottom end ?
    Feb 2006
    57,148
    Main bearing studs. Halfcase stud girdle. Oil pan/oil distribution plate is a totally different critter, BUT is still a structural member of the cylinder block.
    Go up to the "Community" tab, open "Albums" and get into my two - the red Seville. There are pictures and diagrams of the halfcase and bearing setup.
    ThumperPup's Avatar
    Mar 2009
    37
    7,688
    i wennt to look for the ALbums in the Community tab area and it looks like it has disapered not sure if it has something to do with the new software update perhaps but i see cadillac owners garage nothing in there but i dont see albums anymore
    Feb 2006
    57,148
    Either in here or go all the way out to the home page. Scroll up to the top - where the Cadillac Technical Archive is in the upper dark bar and the Community tab is in the lower, smaller bar. Albums are in there, right now..................Cadillac Garage is a long way from the top of the Forums pages.
    The bar tabs go: New Posts; FAQ; Calendar; Community, ........., ..........
    vincentm's Avatar
    vincentm is offline Cadillac Owners Connoisseur
    Automobile(s): 1997 Cadillac Eldorado ETC
    Aug 2010
    Kennewick WA
    38
    4,848
    Love the NP engraving! F'n suhweeet!
    ThumperPup's Avatar
    Mar 2009
    37
    7,688
    not sure why i feel stupid or blind because i couldnt find the album tab
    so i just wnet into your profile and open it up from there
    miwise is offline Cadillac Owners Fanatic
    Automobile(s): 1999 Cadillac Seville STS
    Jul 2010
    Lafayette, Louisiana, United S
    39
    447
    Nice! I may buy a set soon! Just so I'll have them if I ever have to take my engine back out again. Thankfully it runs beautifully!
    Hogg is offline Cadillac Owners Member
    Automobile(s): Cadillac 1998 STS
    Nov 2008
    Woodstock Canada
    99
    Quote Originally Posted by 97EldoCoupe View Post
    So long as you have a competent operator. Let an idiot run a CNC machine for a shift and I have seen 8-12hrs of scrap produced.
    A good CNC program coupled with a good operator can really knock out the product quick.
    Hope all is well Jake.
    peace
    Hog
  16. #14
    Mar 2007
    31
    2,600
    Thanks Hogg I have no doubts whatsoever it will take some practice getting experienced with that CNC - so I'm going to schedule myself two days off or something to learn and maybe get a guy over here to show me how to run the unit. Once that thing is running it should be automatic for the most part (yes will need tool changes, "zeroing" etc. every so often) - the one I found comes with an automatic bar feeder) but if need be I will hire someone to run it. I have to know either way how to run the machine.
  17. Remove Advertisements
