Have code P071 & P046
Results 1 to 2 of 2
Northstar Engines and System Technical Discussion Discussion, Have code P071 & P046 in Cadillac Engine Discussion; My car has been throwing codes and running rough for the passed few months. It shakes pretty bad (and sounds ...
    1987FieroGT is offline Cadillac Owners Member
    Jun 2011
    23
    13
    My car has been throwing codes and running rough for the passed few months. It shakes pretty bad (and sounds like a mis). I finally was able to pull the codes. I got two codes, P071 and P046.
    P071: Intermittent Map Sensor Signal
    P046: Front-To-Rear Bank Fueling Imbalance.
    Whats my first step of solving these issues? I pulled my map off to make sure that gasket was not broken, its not broken. Is there sometype of mutimeter test I could do on the map plug? Could the intermittent map cause my fueling imbalance?
    69
    82,265
    Re: Have code P071 & P046
    Update your profile to show the year and model of your car. It would help in determining the age and we wouldn't have to ask.
    I'd probably start by replacing the MAP sensor.
