proper torque-to-yield on 99 sts
Results 1 to 14 of 14
Northstar Engines and System Technical Discussion Discussion, proper torque-to-yield on 99 sts in Cadillac Engine Discussion; I am at the point of tightening my head-bolts, and the FSM says tighten to 30 lbs/ft on first pass, ...
    knon2000 is offline Cadillac Owners Member
    Automobile(s): 2005 STS 2009 CTS
    Sep 2009
    49
    48
    I am at the point of tightening my head-bolts, and the FSM says tighten to 30 lbs/ft on first pass, second pass -70 degrees, third pass also 70, with final pass at 60 degrees for a total of 200 degrees.
    This is not what I have seen listed in several threads? Which method should I use?
    I also seem to remember something being mentioned about the timing method listed in the FSM not being correct. I can't for the life of me find that thread back, is
    there anything to that? The shop manual seems pretty dang detailed to be incorrect, but, hey, we are all human.
    Thanks
    JoeTahoe is offline Cadillac Owners Enthusiast
    Automobile(s): 2001 GMC SLT, Malibu LTZ, 99 STS studded with NP
    Jul 2010
    Central, NY
    48
    502
    Re: proper torque-to-yield on 99 sts
    are you useing studs and nuts or stock head bolts??
    Sep 2009
    49
    48
    felpro "stock" head bolts, sorry, didn't think to mention what I was using.
    98eldo32v's Avatar
    98eldo32v is offline Cadillac Owners Connoisseur
    Automobile(s): 98 eldo/KD54 w/N37,T96,QA1,D55,DS3,U1Z. U3R next
    Apr 2010
    51
    2,126
    You're using stock head bolts? WOW?!
    89falcon is offline Cadillac Owners Fanatic
    Automobile(s): my wife crazy, 1997 STS, 2004 CTS
    Apr 2011
    188
    Quote Originally Posted by knon2000 View Post
    Thanks
    IIRC, all of the talk about incorrect timing methods in the manual pertain to the 3.6 liter V6....the engine actually has different colored links in the chain instead of timing "marks"......the only strange thing about the N* timing is that if you rotate the crank 720 degrees, the crank mark will NOT line up with the mark on the intermediate sprocket.
    Bad call on the Headbolts IMO. If you're sticking with bolts, you should only do so with "Norm's" inserts....and if you use the bolts, you should be using the factory ones......I've heard of problems with aftermarket bolts......
    I think there was a TSB that went out about the procedure......and the new procedure puts even more stress on the bolts in an attempt to get a little more clamping force.....but with more failures during installation....
    Sep 2009
    49
    48
    I made my own inserts. Much better than Norm inserts, at least in my opinion. I don't know that factory bolts would be better than felpro, and considering Jake's well known quality control issues, I really don't feel the least bit worried about using a company with a felpro's quality record.
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    55,915
    Absolutely nothing wrong with either GM stock or any of several name brand aftermarket head bolts. If it's not gong to Daytona or Talleadega there's no need to go with something like top-drawer ARP.
    The timing chain setup is in a diagram in one of my two red Seville albums up in Community, Albums.
    Apr 2011
    188
    Better than Norm's? in what way? are they longer? bigger?
    Sep 2009
    49
    48
    They are longer. I also included the locating dowel on the inserts.
    Made it really easy to remove by just drilling them out using the inserted fixture
    that I built.
    Really helps that I am a machinist with access to the materials that are needed.
    Jul 2010
    Central, NY
    48
    502
    if no one answers you on the torque spec. I will when I get it from my FSM when I get home from work
    Sep 2009
    49
    48
    No problem on the torque spec. I was just questioning it since I thought I remember reading a thread where someone was recommending lower starting torque and yeild angles.
    I already have the FSM, thanks anyway.
    Kevin
    stoveguyy is offline Cadillac Owners Connoisseur
    Automobile(s): 03 STS
    Aug 2007
    mpls mn
    2,528
    longer is nice but how do you know how much material is at bottom of threaded hole? do you have a block diagram from GM? seen a few comments on cracked blocks due to using oversize thread inserts. sure there is a limit on thread diameter and thread depth. so you might say your inserts are better since they are a "little" longer.
    97EldoCoupe's Avatar
    97EldoCoupe is offline Cadillac Owners Connoisseur
    Automobile(s): 97 ETC x2, 04 GXP, 04 STS x2, 97 ESC, 99 Deville, 05 SRX
    Mar 2007
    London, Ontario and Winkler MB
    31
    2,618
    and considering Jake's well known quality control issues.
    I will take note of this comment for future reference.
  16. #14
    tateos's Avatar
    tateos is offline Cadillac Owners Connoisseur
    Automobile(s): 1997 ETC (GAVE TO STEPSON 2011), 2000 DTS (RIP)
    Jul 2007
    FOUNTAIN HILLS, AZ
    60
    1,704
    I used Norm's - before Jake's time - and FelPro bolts - snapped 1 bolt on install. Removed all 10 on that (R) bank, removed the broken remains, Rock Auto sent me a complete new set no charge. All of Norm's inserts were still fine, including the one in the problem hole. No issues the second time around or with the L bank - I think it was a fluke.
    I used the 30/70/70/60 procedure.
    P.S.: For you guys that know/remember me, Numb Nuts is still driving the car...with no more DUI incidents lately!
  17. Remove Advertisements
