Time sert removal
Results 1 to 14 of 14
Northstar Engines and System Technical Discussion Discussion, Time sert removal in Cadillac Engine Discussion; I have been reading about the stud kits and was wondering if you can just drill the time serts if ...
    Davidis33 is offline Cadillac Owners Member
    Automobile(s): 2002 deville
    Jul 2011
    Denver CO
    3
    Time sert removal
    I have been reading about the stud kits and was wondering if you can just drill the time serts if they have been installed or if they need to be removed before you can drill for the studs. If they need to be removed first how do you do it?
    Jesda's Avatar
    Jesda is offline Super Moderator
    Automobile(s): 2002 Seville STS F55, 2006 Mazda Miata
    Sep 2003
    DETROIT
    35
    22,381
    Re: Time sert removal
    Thread moved from 06+ DTS to Northstar Technical
    johnny kannapo's Avatar
    johnny kannapo is offline Cadillac Owners Connoisseur
    Automobile(s): 1996 Eldorado
    Oct 2009
    Pigseye, Mn
    56
    2,814
    If you already have inserts you are kind of committed to them. I'm pretty sure they are bonded in with locktite & removal would be difficult if not impossible without causing damage to the threads that may not be repairable.
    You certainly could use a studs with the inserts. You would use a more conventional stud that doesn't step up in thread diameter on the block side.
    ThumperPup's Avatar
    ThumperPup is offline Cadillac Owners Master
    Automobile(s): not anymore 2007 Lexus ES350
    Mar 2009
    Murray/ Snowbird Utah
    37
    7,688
    Quote Originally Posted by johnny kannapo View Post
    johnny i think Jake has said that his studs can be used with Time Serts and Norm Serts you have to drill again
    how ever i think he said if you have big sert's then you can't use them and you are in the business for a new block
    but i belive he does say that they can be used in an engine that was time serted
    Speedygman is offline Cadillac Owners Fanatic
    Automobile(s): NorthStar 32 Vicky/ 58 CHEVY BROOKWOOD 348, 1983 Manta RX7
    Mar 2011
    Juliette Ga.
    74
    171
    Found this picture of removing time sert.
    69
    82,268
    That's no Timesert. It looks more like a Helicoil.
    This is a Timesert.
    vincentm's Avatar
    vincentm is offline Cadillac Owners Connoisseur
    Automobile(s): 1997 Cadillac Eldorado ETC
    Aug 2010
    Kennewick WA
    38
    4,848
    Quote Originally Posted by Speedygman View Post
    Yea, thats a helicoil
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    56,827
    Remember: Jake's studs use a larger diameter coarser thread on the block end than OEM bolt threads, so you must drill and tap the block for Jakes studs.
    Timeserts and Norm's Inserts use either the stock GM head bolts (M11 X 1.5) OR the VW cylinder jug studs/top nuts/washers from ARP.
    Timeserts have an expanding lower thread design - the head bolt is torqued and that literally locks the 'sert into the hole. Look closely at Ranger's picture.
    NEVER, NEVER use Helicoils as thread repair in a Northstar block head bolt hole.
    maeng9981's Avatar
    Mar 2009
    Dallas, TX
    25
    3,993
    Helicoils: NEVER A FIX FOR NORTHSTARS, DO YOU WANT TO PUT THAT IN YOUR ENGINE HOPING TO HOLD ALL THE FORCE?
    Mar 2011
    Juliette Ga.
    74
    171
    Some professional auto mechanic saw fit to do this repair with helicoils, some things never change P.T.Barnam said it best. A fool and his money are soon parted or something like that.
    ternstes is offline Cadillac Owners Fanatic
    Automobile(s): 2011 CTS V, 2007 SRX V8, 2005 CTS 3.6L, 2000 STS, 1999 STS
    Nov 2008
    SW Ohio
    36
    393
    According to the timesert website, you can use a bolt extractor to remove a timesert.
    http://www.timesert.com/html/usefultools.html
    Would this work with the timesert deep in the headbolt hole? I am more curious than anything...
    Feb 2006
    56,827
    Can't see why it wouldn't - I've pulled some pretty weird broken stuff with EZ-Outs.
    The business of the bottom 3 threads expanding to lock the insert is what intrigues me...........(as in: cylinder block cracks)
    stoveguyy is offline Cadillac Owners Connoisseur
    Automobile(s): 03 STS
    Aug 2007
    mpls mn
    2,527
    if OD of timesert is smaller than thread for stud/norms than it can be drilled out. its just a metal shell. imho. now if a person chimes in who has done this than we have more info.
  16. #14
    Oct 2009
    Pigseye, Mn
    56
    2,814
    Quote Originally Posted by submariner409 View Post
    This swedge expansion of the lower thread blows removal out of the water with out re-drill & tap larger yet.
    I mentioned before you are kinda commited if you have inserts, you actually are solidly committed to them if them draw out a thread with an interfernce fit.
    Its basically damaging the thread beyond use turning it out & will need re-work if that's still possible.
  17. Remove Advertisements
