Engine swap question
Results 1 to 3 of 3
Northstar Engines and System Technical Discussion Discussion, Engine swap question in Cadillac Engine Discussion; I have an 01 dts vin 9 that needs a engine and trans and was wondering if a 00 deville ...
    Indian Outlaw is offline Cadillac Owners Member
    Automobile(s): 01 DTS
    Jul 2009
    55
    1
    I have an 01 dts vin 9 that needs a engine and trans and was wondering if a 00 deville vin y would work? i would like to buy the 00 and switch the complete engine, trans, cradle etc. Is the only difference the horsepower rating?and maybe exhaust manifolds? Is the harness the same with the different speedo clusters? Thanks for you help. Ike.
    68
    81,928
    Re: Engine swap question
    Different intake cams, different final drive ratio and difference PCM. Swap it all and you essentially have a base Deville/DHS drivetrain.
    Also see the Nortstar swaps sticky above.
    stoveguyy is offline Cadillac Owners Connoisseur
    Automobile(s): 03 STS
    Aug 2007
    mpls mn
    2,528
    where do you find cars with both bad motor and trans? seller always says 1 or the other is ok. hard to check trans performance with non-running motor.
