4.0 rebuild
Page 1 of 4 1 2 3 4 LastLast
Results 1 to 15 of 48
Like Tree1Likes
Northstar Engines and System Technical Discussion Discussion, 4.0 rebuild in Cadillac Engine Discussion; so ive decided to just rebuild mine, the whole thing that started the rebuild was some metal and plastic in ...
    aurora guy is offline Cadillac Owners Member
    Automobile(s): none
    May 2011
    25
    20
    4.0 rebuild
    so ive decided to just rebuild mine, the whole thing that started the rebuild was some metal and plastic in the pan. i tore in to it and found no real bad bearing damage, just some signs of overheating. crank and rods in great condition, just gunna have the crank machenied,new bearings and of course gaskets. it all torn apart now, heres a few pics
    pile of parts
    carbon !
    timing chains
    something i found odd, no cam bearings
    also a few questions for you gurus
    1. rod bolts, does anybody make good after market ones ? like arp
    2. you guys know of anywhere to buy bearings cheap, but good quality ?
    thanks
    JoeTahoe is offline Cadillac Owners Enthusiast
    Automobile(s): 2001 GMC SLT, Malibu LTZ, 99 STS studded with NP
    Jul 2010
    Central, NY
    48
    502
    Re: 4.0 rebuild
    I used gm rod bolts. And Clevite Bearings from Rock Auto
    89falcon is offline Cadillac Owners Fanatic
    Automobile(s): my wife crazy, 1997 STS, 2004 CTS
    Apr 2011
    188
    Re: 4.0 rebuild
    Have you though about putting a 4.6 block in it?
    Be sure to get the rods journals checked for roundness before you put it back together....I here the deform....and if they aren't round, you'll be doing it all again soon!
    johnny kannapo's Avatar
    johnny kannapo is offline Cadillac Owners Connoisseur
    Automobile(s): 1996 Eldorado
    Oct 2009
    Pigseye, Mn
    56
    2,814
    Re: 4.0 rebuild
    What year model is your northstar?
    How many miles?
    It looks pretty good.
    Many here will be interested in following this thread.
    I kind of like how the 4.0L cylinders are so much heftier looking than a 4.6L.
    Oct 2009
    Pigseye, Mn
    56
    2,814
    Re: 4.0 rebuild
    Any professional crank/cam grinder will provide you with the proper spec. bearings.
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    55,900
    Re: 4.0 rebuild
    Remember: the GM Factory Service manual says "Do not machine the crankshaft bearing journals".
    Jul 2010
    Central, NY
    48
    502
    Re: 4.0 rebuild
    mine had 130000 miles and the crank was still in spec. also if you do rering I have read horror stories on non GM rings, smoking and useing tons of oil. I have rebuilt two Northstars a Eldo and my Sts and used GM rings with great success.
    97EldoCoupe's Avatar
    97EldoCoupe is offline Cadillac Owners Connoisseur
    Automobile(s): 97 ETC x2, 04 GXP, 04 STS x2, 97 ESC, 99 Deville, 05 SRX
    Mar 2007
    London, Ontario and Winkler MB
    31
    2,618
    Re: 4.0 rebuild
    You have to be careful with the clevite bearings. Great quality- but the thrust bearing sometimes need filing from the backside because of raised edges during the crimping process. I've found a couple that I would not use without a bit of very careful filing otherwise the bearing wouldn't have seated properly.
    From what I can see in the photos that is a 1995-1997.5 Aurora. I think you may be a customer of mine with the initials of T.C.? If so- that timing kit is definitely needed, that lower tensioner looks a bit worn. When you get the timing kit use the bolts that I sent along as the guides are the newer style (1997.5+).
    Looks like a great job so far, should be an awesome car again. The studs finally came in last night so orders are being filled and shipped. Again if I'm correct about who you are, the drilling and tapping kit has already shipped and is on the way so that you can get the block prepared.
    Great job and wish you the best with the build-up!
    postman2000's Avatar
    postman2000 is offline Cadillac Owners Fanatic
    Automobile(s): 1996 STS 2000 Deville
    May 2009
    296
    Re: 4.0 rebuild
    Is there anything one can do as far as normal maintainence do minimize the carbon on top of the pistons like the pic's above? I am aware of the W.O.T. procedure, but will one particular kind of gas or oil help to minimize this?
    Feb 2006
    55,900
    Re: 4.0 rebuild
    Carbon deposits are, unfortunately, a normal byproduct of petroleum combustion.
    Oil burners and city driven engines (cold combustion chambers) tend to develop excessive carbon deposits. Highway engines and those subjected to occasional "spirited driving" tend to stay much cleaner.
    If you're a tad paranoid, do some Google work on Chevron TECHRON. Used according to the directions it MIGHT help a bit. GM likes the Top Tier gasolines - Google that, too.
    May 2009
    296
    Re: 4.0 rebuild
    Thanks for the tips Sub, I usually throw in a chevron techron every month or so.. Hopefully it helps some..
    stoveguyy is offline Cadillac Owners Connoisseur
    Automobile(s): 03 STS
    Aug 2007
    mpls mn
    2,528
    Re: 4.0 rebuild
    can you include a closeup pic of the piston ring grooves if you can? before cleaning. would like to see if the story of carboned up ring grooves is true. oh, the cam does not have bearings. thats why oil changes are important.
    Oct 2009
    Pigseye, Mn
    56
    2,814
    Re: 4.0 rebuild
    The oil control ring assembly is the the ring that is the most problem. The top & second ring can only build up on the inside vertical groove wall and ring movement would keep these self clean for the most part but the combustion heat & oil presents causes it to bake on hard.
    The 3 piece oil control ring has many areas for carbon to collect. The ring gets stuck and the 2nd ring becomes overwhelmed with oil then up to the top ring.
  16. #14
    auroradude's Avatar
    auroradude is offline Cadillac Owners Fanatic
    Automobile(s): 95 Aurora, 08 Z06
    Jun 2005
    WC, PA
    28
    244
    Re: 4.0 rebuild
    Why rebuild it? I just bought a brand new leftover Aurora V8 from the Shelby plant, in a crate that says shelby, inc on it. Everything is new top to bottom - can't wait to put it in my car. There is one left, I paid $2000 + shipping for mine, but the last one for sale is bid up to $2700 now plus $400 shipping.
  17. #15
    Feb 2006
    55,900
    Re: 4.0 rebuild
    =stoveguyy;2616318 oh,the cam does not have bearings.
    ????? All four cams have line bored bearings - lots of them.
    Pictures ???? Go look at the slew of shots taken by JoeTahoe in his engine rebuild thread. Same engine, only 0.6 litre larger. Plenty piston pics............
  18. Remove Advertisements
