Code question?
Results 1 to 3 of 3
Northstar Engines and System Technical Discussion Discussion, Code question? in Cadillac Engine Discussion; 2004 SRX Northstar. 60k miles. We're the original owners. Has always run flawlessly. Today, check engine light came on, and ...
    afsfuel is offline Cadillac Owners Member
    Automobile(s): Cadillac SRX, Cadillac Seville
    Apr 2008
    CA 92067
    8
    Code question?
    2004 SRX Northstar. 60k miles. We're the original owners. Has always run flawlessly. Today, check engine light came on, and car started running rough at all rpm's. Checked with my code reader: P0304 & P0305. Indicates misfire on cylinders 4 & 5. Anything special to look for other than plugs & wires?
    Ed
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    56,822
    Re: Code question?
    I believe your engine has no "wires" - it's individual C-O-P.
    Look for poor wiring connectors, injector connectors, vacuum leaks ???
    You might want to post this up in SRX - it seems that this forum is populated more by the pre-2004 4.6 engines.
    Apr 2008
    CA 92067
    8
    Re: Code question?
    OK, thanks.
