Out the top! First time....
Page 1 of 2 1 2 LastLast
Results 1 to 15 of 19
Like Tree1Likes
Northstar Engines and System Technical Discussion Discussion, Out the top! First time.... in Cadillac Engine Discussion; Im working on my black 97. I wanted to leave everything else untouched, so decided to join the dark side ...
    ponyboyt is offline Cadillac Owners Enthusiast
    Automobile(s): 97, 97, RIP 98, 99 STS with Jakes studs
    Apr 2009
    Ontario, Canada
    40
    721
    Im working on my black 97. I wanted to leave everything else untouched, so decided to join the dark side and give her a try out the top. So im almost ready. Harness is a PITA under the brake booster, but its all off and hanging on the side of the car, i disconnected most of what wasnt attached to the engine itself.
    Everything else so far has been pretty slick except for a minor exhaust hang up. I have the last bellhousing bolt to do, and the bracket above it and its all apart. They dont look easy to get at at all..... Im looking for a couple pointers for the next one; like whether to take the whole harness off, or just the front, or just the back? Seems leaving the harness attached to the car and just get everything off the engine is easiest.
    I may do the other black 97 next, and ill be posting pics of that process. Man its a lot easier having a hoist.....
    amunderdog and amunderdog like this.
    vincentm's Avatar
    vincentm is offline Cadillac Owners Connoisseur
    Automobile(s): 1997 Cadillac Eldorado ETC
    Aug 2010
    Kennewick WA
    38
    4,871
    Call me 5092051255
    Sent from my Northstar powered phone
    Apr 2009
    Ontario, Canada
    40
    721
    Re: Out the top! First time....
    shes out. Couple things I will change for next time... remove the alternator and A/C compressor first.
  5. #4
    vincentm's Avatar
    Aug 2010
    Kennewick WA
    38
    4,871
    Woohoo! Congrats! \o/!
  6. #5
    maeng9981's Avatar
    Mar 2009
    Dallas, TX
    25
    3,997
    Now THAT is some impressive work!
  7. #6
    drewsdeville is offline Cadillac Owners Master
    Automobile(s): 2011 Crown Vic LX, 2009 Chevy Malibu 2LT
    Oct 2004
    Oak Creek, WI
    5,609
    Looks good man.
    Have you dropped it out of the bottom before?
    I'd like to hear some input from someone who has done it both ways. All of the engine pulling I've done has been out the top. I don't have a lift, and it seems easiest to me given the equipment I have. I've never done a N*, but frankly, pulling other FWD's out the top really haven't been a big deal. I find it hard to believe that, in comparison to dropping out the bottom, pulling out the top is as bad as some make it sound.
  8. #7
    98eldo32v's Avatar
    98eldo32v is offline Cadillac Owners Connoisseur
    Automobile(s): 98 eldo/KD54 w/N37,T96,QA1,D55,DS3,U1Z. U3R next
    Apr 2010
    51
    2,126
    Congratulations!!! To me that's the easiest way to go.
    The pull a parts around here must have some northstar "out the top experts". Every single one I've ever looked at came out the top and looked like your pictures.
    Good luck with the repair.
  9. #8
    Apr 2009
    Ontario, Canada
    40
    721
    I did 2 others out the bottom this week, before this one. One was a swap. Id say they are comparable to how easy each way is. Its AFTER the swap where you can run into trouble. Brake lines... allignment etc... Out the top leaves no other work to be done. Im doing them ALL this way if i dont have too many issues putting the other engine in. Getting all those brackets back on may prove to be.... tedious.
  10. #9
    Apr 2009
    Ontario, Canada
    40
    721
    quick question.
    Ive been looking at them: the front engine mount, and the passenger side mount. Are they the same on pre-98 cars? The front on this one is broken, (and all the other ones i have), but the side mounts are all good. They LOOK the same.....
  11. #10
    Apr 2009
    Ontario, Canada
    40
    721
    TThe mounts arent the same, close but no.
    Anyhow, spent the last week moving and packing my house... and moving... in 32 degrees sun in a diesel Z71 with no A/C
    So i took a break today, picked my other engine up off the floor, and got this far:
    Shes in and flush, popped in the upper 2 bellhousing bolts, propped my little jack underneath and called it a day.
    Wasnt so bad at all, coulda done it a LOT quicker if i'd realised there was a bracket on the back of the block (firewall side) that had its twin still bolted to the trans. They didnt like each other. Oops.
  12. #11
    Apr 2009
    Ontario, Canada
    40
    721
    took it out for a test run and washed it today. Runs a bit off, lots of low end power but doesnt like high RPM. Some things to look at i guess. I didnt use the intake originaly on that engine. Otherwise everything is solid. Even my "rigged" broken front engine mount is solid. (I'll get into that later).
  13. #12
    89falcon is offline Cadillac Owners Fanatic
    Automobile(s): my wife crazy, 1997 STS, 2004 CTS
    Apr 2011
    188
    Quote Originally Posted by ponyboyt View Post
    Did you pull off the valve covers? It's kind of a "weird" quirk......that I learned the hard way on a flat tappet vette engine, but a "worn" cam will actually give you MORE power at low RPMs (lower lift, lower duration) than a "good" cam. I think there is a good chance (especially on a 97 model motor) that you have a couple bad cam lobes.
    Also, are you sure it's a Vin9 motor? Not a big deal if it isn't, you only need to swap out the intake cams with your old motor, and it's a Vin 9 motor again.
  14. #13
    Apr 2009
    Ontario, Canada
    40
    721
    its a vin 9, manufactured November 2001. Around 110,000 km's on this engine. Its burning oil, more than normal. Smokes blue on startup if it was a hard start. Some times smokes randomly while sitting there idling. Had this problem in the car it used to be in. Im wondering about the emissions parts, evap etc.... i dabble in it here and there.... too many cars on the go right now.
  15. #14
    ThumperPup's Avatar
    ThumperPup is offline Cadillac Owners Master
    Automobile(s): not anymore 2007 Lexus ES350
    Mar 2009
    Murray/ Snowbird Utah
    37
    7,696
    Quote Originally Posted by 98eldo32v View Post
    chances are they don't care what els they damage in the process they just take it out the top cause they don't want to have to pull out exuipment or move the car from where they sit
    atleast i very rearly ever see a bone yard that does not just cut stuff up to get things out and don't care what they damage they just want the part out fast atleast the techs do and then they don't ever get in trouble when another good part cant be used they just say it was not good to begin with
  16. #15
    stoveguyy is offline Cadillac Owners Connoisseur
    Automobile(s): 03 STS
    Aug 2007
    mpls mn
    2,528
    i did not inspect my cam lobes for wear when i had my heads off. chased a miss for 2yrs and its finally gone now with different plug wires. did not have intermediate chain tensioner off so did not inspect it for guide wear. am pretty sure my motor is timed right. but still cannot spin the tires.
  17. Remove Advertisements
