y VS 9 ENGINE???
Results 1 to 11 of 11
Northstar Engines and System Technical Discussion Discussion, y VS 9 ENGINE??? in Cadillac Engine Discussion; Can someone please explain the difference between the Y and the 9 engine. I'm sure I read here there was, ...
    fredcrn's Avatar
    fredcrn is offline Cadillac Owners Member
    Aug 2004
    Wilmington, NC
    66
    51
    y VS 9 ENGINE???
    Can someone please explain the difference between the Y and the 9 engine. I'm sure I read here there was, but can't remember. My VIN tells me I have a 9, based on 8th figure of the VIN, right?
    Thanks
    Fred
    68
    81,926
    Re: y VS 9 ENGINE???
    The only difference is the intake cam and 25 more HP on the vin 9. The vin y has more torque and HP til about 4000 RPM then the vin 9 overtakes it. Final drive ratio is also different.
    Geno Castellano is offline Cadillac Owners Fanatic
    Jan 2003
    223
    Cam timing is the reason for the power difference. The intake cams are the only difference between the LD8 and the L37 engines from 1993-1999. On the 2000 and later engines both the intake and exhaust cams are different.
    ljklaiber's Avatar
    ljklaiber is offline Cadillac Owners Fanatic
    Automobile(s): 1995 SLS 200K miles
    Jan 2003
    Georgia
    76
    372
    I might add that the final drive gear ratio is taller in the sls and shorter in the sts. My 95 sls is better in roll on races than in stop and go. My wife loves her new Accord EX Coupe. Quick off the line! Caddy wins the roll on....Love ya Gal! Never race yer WIFE!!!...LOL
    CadiJeff's Avatar
    CadiJeff is offline Cadillac Owners Connoisseur
    Automobile(s): 1981 CoupeDeville, 2 1990 Eldorados, 1994ETC ,1992STS
    Feb 2004
    Nerk,Ohio
    36
    1,072
    Geno whats the deal w/ the 05 northstar nhp? 290 hp and 285lb-ft
    what is the difference there and why? Those #s are worse than my 94 etc!
    Jan 2003
    223
    There are some differences in the horsepower rating procedures that went into place. The SAE standards for testing "advertised power" are changing to commonize certain features, eliminate ambiguities in test setup, etcetera. That results in lower advertised power numbers in most cases. For instance, the engine has to be tested now with the complete accessory drive system in place where as before it was not and the power for the generator, etcetera was mathemitically corrected. The engine makes the same power as it always did. It's just the rating system being phased in. It's only "lesser" on paper...
    CadiJeff's Avatar
    Feb 2004
    Nerk,Ohio
    36
    1,072
    ah so every one got screwed, or should I say torqued? lol
    fredcrn's Avatar
    Aug 2004
    Wilmington, NC
    66
    51
    Thanks for the info.
    Fred
    Jan 2003
    223
    Quote Originally Posted by CadiJeff
    Nobody got screwed at all, actually. The engine is still at the same power level and the car performs the same. Just the advertised (on paper) power number used for marketing is slightly lower.
    RAD
    RAD is offline Cadillac Owners Member
    Automobile(s): 1992 STS, 1993 STS, 2000 STS
    Jan 2004
    34
    ...Possibly an influence on insurance companies with a resulting benfit on premiums, or is the impact too slight?
    Quote Originally Posted by Geno Castellano
    CadiJeff's Avatar
    Feb 2004
    Nerk,Ohio
    36
    1,072
    I say screwed because 300 hp/295 torque sounds alot better than 285 hp/280 torque
    and by everyone i meant car mfgs
  14. Remove Advertisements
