P039 Code On Torque Converter/Clutch How to fix, What does this mean?
Results 1 to 2 of 2
Northstar Engines and System Technical Discussion Discussion, P039 Code On Torque Converter/Clutch How to fix, What does this mean? in Cadillac Engine Discussion; My 94' Seville SLS has a P039 code on. It says torque converter/clutch engagement issue. I cleared the codes and ...
    Twilightcall's Avatar
    Twilightcall is offline Cadillac Owners Fanatic
    Oct 2003
    TN
    143
    My 94' Seville SLS has a P039 code on. It says torque converter/clutch engagement issue. I cleared the codes and restarted the car and drove it some more and it didn't come back on. However, I do feel a vibration when I first get back on the gas. Is this a serious problem or ?. Any info would be appreciated. Thanks.
    wake's Avatar
    wake is offline Cadillac Owners Enthusiast
    Automobile(s): 2007 STS-V, 2007 Escalade, 2003 Escalade EXT
    Sep 2003
    Stafford, VA
    812
    Re: P039 Code On Torque Converter/Clutch How to fix, What does this mean?
    Check out caddyinfo.com
    I posted a TSB on there a couple years ago that I found dealilng with this issue on VIN Y cars (SLS, ESC, DeVille)... Basically it's just a PROM upgrade that opens up the slip limits of the TCC... It's not a cure all, but it might help... It prevented the reoccurrence of P039 on my old 94 ESC for almost 2 years, until the TCC slip got worse and again set off the code...
    It should be under the searchable archives or the FAQ section...
    I'm not sure about the vibration as mine didn't do that...
    Jim
