94 eldo cooling problem
Results 1 to 3 of 3
Northstar Engines and System Technical Discussion Discussion, 94 eldo cooling problem in Cadillac Engine Discussion; show message engine hot. Have replaced the thermostat, coolant levels ok, fans come on around 238 degrees but temp continues ...
    bmeyermo is offline Cadillac Owners Member
    Automobile(s): 1993 Eldorado Touring
    Oct 2005
    Indian Nation
    11
    show message engine hot. Have replaced the thermostat, coolant levels ok, fans come on around 238 degrees but temp continues to rise. what should I check next? Any and all help appreciated
    vincentm's Avatar
    vincentm is offline Cadillac Owners Connoisseur
    Automobile(s): 1997 Cadillac Eldorado ETC
    Aug 2010
    Kennewick WA
    38
    4,872
    Re: 94 eldo cooling problem
    Have a block test and/or leak down test done to check for blown head gaskets.
    68
    81,926
