It's been asked before, but more specifically.ACD 41-OEM Sparkplugs vs Denso Iridium
Results 1 to 7 of 7
Northstar Engines and System Technical Discussion Discussion, It's been asked before, but more specifically.ACD 41-OEM Sparkplugs vs Denso Iridium in Cadillac Engine Discussion; Im at 109K miles.... Denso is the OEM for the N* double platinum spark plugs (AC Delco 41987 double platinums ...
    mtflight's Avatar
    mtflight is offline Cadillac Owners Connoisseur
    Automobile(s): 1999 White Diamond ETC
    Jan 2005
    Dallas, TX
    2,538
    Denso is the OEM for the N* double platinum spark plugs (AC Delco 41987 double platinums are EXACT same plug as DENSO PT16EPR13 aka 5092).
    As per the Denso site (http://goo.gl/TyKuB ), their Iridium plugs are compatible with the N*
    Rock Auto page for AC Delco 41-987 http://www.rockauto.com/catalog/moreinfo.php?pk=89945
    Rock Auto page for DENSO 5092 (same spark plug as above) http://www.rockauto.com/catalog/moreinfo.php?pk=993026
    Here's the Rock auto page for the Denso Iridiums: http://goo.gl/24G7u
    So what's your take? Not worth the extra dollars or not a noticeable upgrade? Reducing the load on something so repetitive would have some kind of advantage, or a fiasco like Bosch plugs in the Northstar?
    My reasoning is the original plugs are DENSO and these are DENSO too--not just a gimmick, same engineering.
    Also, would there be a noticeable improvement in MPGs with new plugs?
    68
    82,070
    Re: It's been asked before, but more specifically.ACD 41-OEM Sparkplugs vs Denso Iri
    I seriously doubt you'd see any difference in mileage.
    92Deville's Avatar
    92Deville is offline Cadillac Owners Member
    Automobile(s): 98 Deville
    Ogden, UT
    39
    52
    Stick with the factory recomendations and put another 100K on it.
    mtflight's Avatar
    Jan 2005
    Dallas, TX
    2,538
    Well they were only $12 more than the factory ones for the whole set. I'll report back if they fail to perform.
    maeng9981's Avatar
    Mar 2009
    Dallas, TX
    25
    3,999
    I just ordered 8 AC Delco 41-987 from ebay. ~$4 each. Trying to stick with AC Delco, proven...
    mtflight's Avatar
    Jan 2005
    Dallas, TX
    2,538
    Quote Originally Posted by maeng9981 View Post
    Yeah can't go wrong. That's what I was going to do, but since the AC Delcos are made by DENSO and according to them their Iridium is one up on their double platinums I took a chance for $1.50 more each than the AC Delcos. $3 more each than the DENSO label double platinums.
    I got them from retailer in case they are a fiasco, I can get a refund/exchange for the ACDelcos/stock DENSOS.
    I notice only the escalade is using Iridiums, all the Cadillacs still use the double platinums when I checked (I hope that's not a sign).
    johnny kannapo's Avatar
    johnny kannapo is offline Cadillac Owners Connoisseur
    Automobile(s): 1996 Eldorado
    Oct 2009
    Pigseye, Mn
    56
    2,814
    The Iridium plugs are a teeny bit less demanding on the coils and that is the advantage to them.
    If a Denso Iridium plug fits the spec. coil life maybe extended by using them. You really can't go wrong using the OEM plug.
  10. Remove Advertisements
