Who has used studs from Northstar Performance ? - Page 2
Page 2 of 2 FirstFirst 1 2
Results 16 to 26 of 26
Like Tree8Likes
Northstar Engines and System Technical Discussion Discussion, Who has used studs from Northstar Performance ? in Cadillac Engine Discussion; Didn't I read sometime back the mike only does sirts ?...
  1. #16
    ThumperPup's Avatar
    ThumperPup is offline Cadillac Owners Master
    Automobile(s): not anymore 2007 Lexus ES350
    Mar 2009
    Murray/ Snowbird Utah
    37
    7,696
  2. #17
    68
    81,941
    Re: How Many Of Us Have Used or Had Jakes Sure Grip Studs from Northstar Performance
    I think he does it with the engine in the car, so that would preclude him from using studs.
  3. #18
    neo126's Avatar
    neo126 is offline Cadillac Owners Member
    Automobile(s): 1994 STS, 2007 Escalade
    Apr 2009
    Washington
    Bought the studs got half the block done so far they are awsome. You can tell the difference but you gotta be careful with putting the studs in the block you shouldn't have to torque them into the block. If you encounter a lot of resistance go back and make sure the threads and hole are clean. I made the mistake of torqing the stud into the block and if the nut goes to far on the stud it will strip the top. Sometimes you gotta break something to learn how to do it right.
  5. #19
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    55,936
    Actually, tightening studs down into the newly threaded block bolt hole is a very, very good way to crack a Northstar block. A little Loktite thread locker and finger tight is all it takes. The fine threaded nuts do the torque work, not the lower stud threads.
  6. #20
    nascartamike's Avatar
    nascartamike is offline Cadillac Owners Member
    Automobile(s): 2002 Eldorado ETC
    Dec 2009
    Fort Hood, Texas
    51
    87
    Does anyone know someone that will install a stud kit in my 2002 Eldorado? The car is with my parents in East Texas. I'm in the US Army stationed in Korea. I'd like the car ready to go when I get back to the States.
    97EldoCoupe and 97EldoCoupe like this.
  7. #21
    Feb 2006
    55,936
    If no one has a shop idea in the lower midwest - You're gonna think I'm crazy, but your best bet might be to set up the car for a truck delivery to Joe Blau (Midwest Cadillac Repair) in Palatine, Illinois about a month before you rotate back Stateside.
  8. #22
    97EldoCoupe's Avatar
    97EldoCoupe is offline Cadillac Owners Connoisseur
    Automobile(s): 97 ETC x2, 04 GXP, 04 STS x2, 97 ESC, 99 Deville, 05 SRX
    Mar 2007
    London, Ontario and Winkler MB
    31
    2,618
    Re: How many of us have used studs from Northstar Performance ?
    North Texas Performance, Dallas Texas. www.northtexasperformance.com
    And Joe @ Midwest does good work too as Jim had mentioned. Believe me a good mechanic is for sure worth the travel time and cost (it saves in the long run)
  9. #23
    stssteve is offline Cadillac Owners Member
    Automobile(s): 1998 Crimson STS now sold/ 2008 cts 1SB Black Raven 3.6DI
    Jun 2008
    Ontario
    31
    I am one of Jake's original customers from Ontario. He studded my 98 STS at 118K mi several years ago and I recently sold the car with 200K mi + last August. The car was running like new without any coolant loss or overheating at all. The repair exceeded my expectations allowing me get get several extra years out of a car that I absolutely loved. When the issue occurred, I was frustrated at GM that they could build a product that I felt was disposable basically in my mind. The dealership highballed me and likely hoped that I'd give up the car for next to nothing while buying another. Well, I'm still a Caddy owner because their product is just that nice to me and Jake made the reapir for much less with a better solution. I would recommend Jake everyday of the week and do to any Caddy owner I know. He knows these cars inside and out. He really cares about his customers too. Jake has an innovative mind and just an overall appreciation for Cadillacs that is hard to find. He clearly went over and above any expectations I had.
  10. #24
    Speedygman is offline Cadillac Owners Fanatic
    Automobile(s): NorthStar 32 Vicky/ 58 CHEVY BROOKWOOD 348, 1983 Manta RX7
    Mar 2011
    Juliette Ga.
    74
    164
    I do.
  11. #25
    IXSLR8 is offline Cadillac Owners Member
    Automobile(s): Cadillac
    Mar 2008
    69
    By the way, I've logged about 20K on my 1996 N* with Norms inserts and ARP Volkswagen studs. No problems.
    Did a second 1995 N* the same way with with 5K logged. No problems yet on it.
  12. #26
    Caddydrummer67's Avatar
    Caddydrummer67 is offline Cadillac Owners Fanatic
    Automobile(s): '02 ETC 32,000 miles 2002 F55 STS 78,000 miles
    Jun 2012
    Black Hills of SD
    240
    I put NSP studs in both my '97 ETC, and '02 STS. Joe did the Eldo, and Jake did the STS. No problems with either.
    As I've said before, Jake is awesome to work with. Joe was also very professional and good to work with as well. Both accomodated my shedule, helped me with transportation and delivered as promised. I would highly recommend Jake's product and either of these guys to install them.
    The one thing the studs can't do is prevent a drunk driver from totalling your parked Eldo in the middle of the night.
  13. Remove Advertisements
