2000 Eldo front cam cover gasket replacement
Results 1 to 2 of 2
Northstar Engines and System Technical Discussion Discussion, 2000 Eldo front cam cover gasket replacement in Cadillac Engine Discussion; Does anyone have a detailed procedure on the steps to change the front valve cover gasket on the N* (closest ...
    pizzano is offline Cadillac Owners Member
    Automobile(s): 2000 Elorado ESC, Crimson Pearl
    Mar 2011
    65
    Does anyone have a detailed procedure on the steps to change the front valve cover gasket on the N* (closest to firewall), what has to be dropped , removed drained etc, pictures would be greatly appreciated also.
    Thanks folks.
    I know there are post about this but havent found a post that goes into depth of the procedure.
    Thank you in advance
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    55,514
    Re: 2000 Eldo front cam cover gasket replacement
    The rear cam cover (right side of the engine in a transverse mount, therefore closest to the firewall) is the toughest. The engine needs to be rocked forward with a come-along and the cradle dropped slightly.
    Your best bet, for a detailed procedure, is the GM/Helm Service manual. www.helminc.com or ebay. For instant gratification, but computer work, take a look at www.alldatadiy.com.
