ignition switch keeps blowing on 02 deville
Results 1 to 3 of 3
Northstar Engines and System Technical Discussion Discussion, ignition switch keeps blowing on 02 deville in Cadillac Engine Discussion; The mechanic shop finally was able to get my 2002 deville started, with the ignition switch fuse. They said it ...
    soccer_eldorado is offline Cadillac Owners Fanatic
    Automobile(s): 02 Deville, 99 deville - both Adriatic Blue
    Miami Florida
    36
    157
    The mechanic shop finally was able to get my 2002 deville started, with the ignition switch fuse. They said it fired right up, idled for 15 minutes, and then the fuse blew again when driven for 30 feet they said. They did it a second time, and it didn't blow, but do you guys think the switch itself might be bad (and would this throw a code)? They still think there is a short somewhere, but I'm guessing this had to happen to somebody here . Another thought is the ignition module/coil pack panels. The car has missfired when pretty hot for some time now.
    Maz
    Maz is offline Cadillac Owners Member
    Automobile(s): 2003 SLS
    Jul 2011
    61
    1
    Re: ignition switch keeps blowing on 02 deville
    I now have exact issue with 2003 SLS. What was the problem?
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    56,884
    Deville has one type of ignition switch, SLS is different. The 2000+ Sevilles had an ignition switch recall.
    Each of these cars ^^^ has two coil cassettes and two ICMs - one in the leg of each cassette - driven by the PCM.
    If the mileage is over 100,000 it's time for plugs, maybe connector boots and an EGR, TB, and IAC cleaning
