94 top intake cover bolts- which side up
Results 1 to 6 of 6
Northstar Engines and System Technical Discussion Discussion, 94 top intake cover bolts- which side up in Cadillac Engine Discussion; I have a stupid question- those 10 or so bolts that hold down the top cover of the intake; bolt ...
    Pete315 is offline Cadillac Owners Fanatic
    Automobile(s): 95 Eldorado
    Feb 2009
    305
    I have a stupid question- those 10 or so bolts that hold down the top cover of the intake; bolt has an oval shape rubber and oval shape steel washer. does the steel washer go against the intake cover or the head of the bolt? I know, there's no such thing as a stupid question. At least that's what my 3rd grade teacher told me.
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    56,822
    Re: 94 top intake cover bolts- which side up
    The indent washer goes on the bolt first, indent down, then the rubber goes on and gets squished into the washer as you torque it down - think of a bottle cap seal.
    69
    82,266
    But don't torque it down too tight. Get the correct torques setting. That is your overpressure relief. In the event of a backfire, the manifold lifts and vents the pressure.
    amunderdog is offline Cadillac Owners Connoisseur
    Automobile(s): 1994 SLS x 2 ---- 1993 Eldorado Sport ----- 1994 Deville 4.9
    Feb 2010
    Sunbright, TN
    1,538
    The search function brought me here
    Hope i am not junking up your thread.
    To your deal. Lube between the bolt head and washer so the bolt can rotate so not to bind and twist the rubber.
    My problem on mostly same subject.
    1993 Eldorado 4.6 Northstar.
    My Rubbers are worn out. Where can i get replacements? Anyone have part numbers?
    This thread
    http://www.cadillacforums.com/forums...ow-better.html
    "There is a service kit that includes all the bolts, washers and grommets as the kit was a retrofit kit for the early 93 Allante intake manifolds".
    Also while pulling the injectors one of the metal clips that holds the wireing to injector just flew away
    I was working with it and it just disappeared.
    So i need one or two of those also.
    Thanks
    69
    82,266
    Might check with Rippy over there >>>>>>>>>>
    Faded Crest's Avatar
    Faded Crest is online now Cadillac Owners Connoisseur
    Automobile(s): '66 SDV, '76 CDV, '76 FWB, '78 CDV, '89 BRM, '91 BRM '92 BRM, '98 Concours, '00 SDV
    Apr 2008
    North Carolina
    45
    3,179
    I'd be surprised if they are still available.. They were '93 and '94 only. Junkyard or maybe you can see what there might be at Lowe's in their oddball nuts and bolts drawers.
  9. Remove Advertisements
