2000 Deville Misfire
Page 1 of 2 12 LastLast
Results 1 to 15 of 18
Northstar Engines and System Technical Discussion Discussion, 2000 Deville Misfire in Cadillac Engine Discussion; I am posting this here because i cannot fogure out how to start a new post..does anyone know what could ...
    postman2000's Avatar
    postman2000 is offline Cadillac Owners Fanatic
    Automobile(s): 1996 STS 2000 Deville
    May 2009
    292
    I am posting this here because i cannot fogure out how to start a new post..does anyone know what could cause a 2000 deville to misfire on cylinders 3 and 4 at the same time.. got a code p0300.. checked with my snap on scanner and found 3 and 4 misfiring..they do not share the same coil pack.. so its a mystery to me.. Also it does not do it all the time..sometimes it will run ok..then the check engine light starts blinking and it runs like crap.. thanks....Charlie
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    57,121
    Re: Frequency of HG Failure by Age & Miles
    Quote Originally Posted by postman2000 View Post
    To start a new thread go back to the main Northstar Performance page and click on the tab "New Thread".
    Misfires can be caused, on our 2000+ engines, by bad coil cassettes, bad ICM (identical for left and right, in the coil cassette leg), bad plugs, carbon tracked plug boots.
    Please ask a Moderator to move this - it will only serve to hijack the OP's thread.
    97EldoCoupe's Avatar
    97EldoCoupe is offline Owner of Northstar Performance
    Automobile(s): 97 ETC x2, 04 GXP, 04 STS x2, 97 ESC, 99 Deville, 05 SRX
    Mar 2007
    The Great White North
    31
    2,600
    Postman2000's misfire problem on #3 and #4 cylinder -
    As Sub said, that could be two coil cassettes in need of replacement, a plug, (boots are not too likely but it does happen, or fuel injectors. If you need injectors I have plenty of new OEM ones.
    May 2009
    292
    Re: Postman2000's misfire problem on #3 and #4 cylinder -
    Hey Jake, how are ya? How is everyone else too... Hey i have some other info about the problem.. It appears that these cylinders only misfire after car has sat for an hour or so or more. It will misfire until car warms up and then goes away.. I replaced the front coil cassette in december 2009, so i dont think that the coil is the problem..And it would be weird for both to go at the same exact time.. How hard of a job is it to do the injectors on this car? I was thinking maybe an intake manifold gasket, but i think these motors have individual gaskets..not sure of that though.. Any insight from fellow forum members would be of great help and much appreciated.. I thank you guys for all of your knowledge and time.. Tomorrows my birthday..I should have known something was gonna happen.. when my ignition coil went it was on christmas eve.. I dont think my car likes me very much..lol.. Thanks...Charlie
    Feb 2006
    57,121
    I DO NOT like the statement: "only misfire after the car has sat for an hour or so......."
    Gotta ask this - Is the engine losing coolant but no leak is apparent ??
    May 2009
    292
    Hey Sub, The Engine does lose coolant..but i know where that leak is.. i was thinking about that dreaded thing myself.. But i had the headgaskets done in 07/09.. So i am leaning in a different direction... just hope i figure this out soon.. I have spent alot of money repairing this car since i had it...just hoping i can catch a break on this one...Charlie
    Mar 2007
    31
    2,600
    Hey Charlie happy birthday my friend -
    We will get to the root of this and I am still expecting a visit from you someday-
    Ok now be careful if you have leaking injectors (have seen quite a few 00+ fail) and they fill a cylinder full of fuel, the engine will be toast the next time you go to start it up. A misfire after you shut the car down and leave it for a while - injector leaks off slowly, drains the fuel rail, the cylinder has a problem trying to burn off all this extra fuel.
    Best and easiest way to test injector leakdown? Raise the fuel rail off the intake, leave all injectors in the rail, have someone turn the key to "run" to pressurize the rail. Watch for any injectors that are dripping fuel, even if very little.
    I have seen a few engines destroyed by leaking injectors. The trick is to catch it ahead of time; and it seems as though you are. If you want a really good deal on 8 brand new, give me a call tomorrow. I don't know how many I have here in Ontario but I will check as soon as Ponyboyt's 99 is back in his hands. Replace them all and be done with it.
    I'm not going to say for sure it's your injectors but from what you're telling me; without being there in person; I'm going to take an educated guess and say betcha that's your problem.
    69
    82,377
    Re: 2000 Deville Misfire
    Post moved to New Thread and cleaned up to view as new thread.
    Feb 2006
    57,121
    OK - Now start looking for fuel leaks - injectors, pressure regulator, (and this is a stretch) fuel pressure itself - if the fuel pump is weak that can cause some weird hard-start conditions.
    May 2009
    292
    Thanks everyone, I will start by checking the fuel pressure and then maybe swap out the regulator.. go from there...
    69
    82,377
    Don't throw parts at it. Pull the vacuum line off the FPR at idle. If there is no gas leaking from the nipple, it's good. If it ain't broke, don't fix it.
    May 2009
    292
    Very weird, car has not misfired since that day. I have been waiting for it to happen again. But its been a few days and no misfire... rather strange.. Hey Sub, i heard 2 million fish died over in maryland.. Do the locals think its natural causes like the media is saying?
    Feb 2006
    57,121
    Hmmmmmmmm.....................Haven't had the TV on for days - need to take a look.
  16. #14
    NHRATA01 is offline Cadillac Owners Fanatic
    Automobile(s): '12 Regal GS, '01 Trans Am
    Jan 2008
    New York
    248
    I'd pull the plugs first, and see what the affected ones look like, ie are they fouled?
    My '03 developed a miss, one of the coils on the cassette went bad. Thank you GM for designing the coils into a single $250 cassette instead of $40 individual units...
  17. #15
    69
    82,377
    I agree, but unfortunately when the engineers design these things I'd bet that cost or ease of replacement parts is not part of they're criteria.
  18. Remove Advertisements
