why is over filling bad ?
Results 1 to 5 of 5
Northstar Engines and System Technical Discussion Discussion, why is over filling bad ? in Cadillac Engine Discussion; just wondeirng like i know ok if you over fill your oil in our N's it will burn back down ...
    ThumperPup's Avatar
    ThumperPup is offline Cadillac Owners Master
    Automobile(s): not anymore 2007 Lexus ES350
    Mar 2009
    Murray/ Snowbird Utah
    37
    7,696
    just wondeirng like i know ok if you over fill your oil in our N's it will burn back down just faster till it got to the right level
    and if you overfill tranny fluid it doenst burn up at all
    and coolant well that should never go low unless you have a leak
    but why is it that we don't want to over fill the system what could happen from overfilling that would be bad ?
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    55,862
    Re: why is over filling bad ?
    Overfill the engine oil all you want - a Northstar will happily leak oil and burn it down to the proper level in short order. Gross overfilling leads to oil foaming and aeration from being whipped by the crank counterweights - this leads to oil starvation and engine destruction.
    Overfill the transmission and it will happily blow the excess out that vent pipe which is clipped to the throttle cable bracket on the engine. Your mess to clean up.
    Overfill the coolant and it will automatically blow off the extra every time the engine warms up - until the system creates its normal cold reservoir airspace. More mess.
    ThumperPup's Avatar
    Mar 2009
    37
    7,696
    ah ok cool was thinking maybe that was the problem dad said he smelled coolant and it hink it was from a overfilled so i took about a qt or so out till i was not able to see it trhw the top of the res anymore too it out the purge line so hopfully that will just make the smell stop and all
    if not then back to the shop she goes
    maeng9981's Avatar
    Mar 2009
    Dallas, TX
    25
    3,998
    Coolant should always be at the half of the tank (where the clear and black plastics meet). There is a big arrow that indicates the FULL COLD line. Checking coolant level when hot will either start boiling over or give you false reading. You should not be able to smell coolant unless you have a leak somewhere.
    Feb 2006
    55,862
    Quote Originally Posted by maeng9981 View Post
    Pup, Here's the side of your coolant reservoir. Look hard - see the FULL COLD legend and arrow molded into the tank top ? The proper coolant level, cold, is right at the black/translucent plastic seam.
  8. Remove Advertisements
