when i get the heater core replaced to i stay Dex or go green
Results 1 to 14 of 14
Northstar Engines and System Technical Discussion Discussion, when i get the heater core replaced to i stay Dex or go green in Cadillac Engine Discussion; OK just as it sounds once i do replace the heater core im thinking going green only reason there is ...
    ThumperPup's Avatar
    ThumperPup is offline Cadillac Owners Master
    Automobile(s): not anymore 2007 Lexus ES350
    Mar 2009
    Murray/ Snowbird Utah
    37
    7,696
    only reason there is dex in there now is because i forgot to tell my Mechanic to use green not dex
    and now from what i hear it would have to be flushed out probably 3 or 4 times in order to get all the dex from the system and even then it might not get it all
    so what should i do
    when it comes time
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    55,890
    Re: when i get the heater core replaced to i stay Dex or go green
    Use DEX-COOL and exchange it every 3 -4 years. Pup, this has been covered a thousand times: DEX-COOL or good ol' green coolant - you take care of the system with regular maintenance and exchanges or it will come back and bite you in the butt.
    ThumperPup's Avatar
    Mar 2009
    37
    7,696
    4 me what i was planning no matter what i use i was gona have it changed once a year in the beginign of Summer each year cause that would be like 35 to 40k every year but is that over doing it ?
    RippyPartsDept's Avatar
    Sep 2007
    Wilmington, NC
    13,986
    yes, that is waaay over-doing it
    ThumperPup's Avatar
    Mar 2009
    37
    7,696
    Ok so only every 2 years is what would be best for me wich would be about 70 or 80 k question or should i say not go by years and jsut knowing that i drive as much as i do just do it every 50 or 60 k question
    Sep 2007
    Wilmington, NC
    13,986
    GM says 5yrs or 150K (i think... someone correct me if i'm wrong)
    many think that is too much time...
    if i was you and wanted to be careful i would just do a 3 year cycle
    97EldoCoupe's Avatar
    97EldoCoupe is offline Cadillac Owners Connoisseur
    Automobile(s): 97 ETC x2, 04 GXP, 04 STS x2, 97 ESC, 99 Deville, 05 SRX
    Mar 2007
    London, Ontario and Winkler MB
    31
    2,618
    5 years and HG's are already rusted half way out with Dex. I have seen this first hand. No longer than 2 years max with dex in the system. Coolant is cheap, HG's are not. Even with the green stuff, I require a 2 year change interval to maintain the 5 year head gasket warranty. I prefer the green.
    I tore my 98 STS engine down about a week ago. No carbon build-up (for some reason ) and the rings were free. HG's were fine. No damage or corrosion. I ran dex in it for the first year, had a heater hose blow and switched to the green. About 2.5 years I had those HG's in that engine. I see no issues down the road, even putting a 5 year warranty on HG work I believe I have very little to worry about and will not have many comebacks, even in the final warranty year: provided the cooling system is maintained as Sub mentions-
    Mar 2007
    31
    2,618
    To each his own opinion.
    Every year= excessive and unneccessary
    Every 2 years = my recommended change interval
    Every 3 years = the limit IMO
    Every 4 years = really pushing it
    Every 5 years = GM's recommended.
    My 2004 Bonneville GXP's HG's looked pretty bad and very rusty. And I did the work in Dec/09. 5 years (+ a few months likely, forget the date of manufacture).
    Dex may have been reformulated at some point and may have been improved, but after what I've seen from both green and orange, green all the way for me. But like I said, to each his own.
    ThumperPup's Avatar
    Mar 2009
    37
    7,696
    so is orange dex the only thing it does is just last longer and have difrant acids in it ?
    and green doesn't last as long but has more acids in it or something i am confused about that
    the reason im worried is how many times would i need to have it flushed in order to make sure all the dex is out since i don't wana mix dex with green and then what about the radiator possible anything could be stuck in there that wont come out and then maybe get mixed in i just don't wana get these screwed up by mixing
    Feb 2006
    55,890
    Don't get confused about anything --------run either green or DEX and change it every 3 years in the spring. Problem solved.
    I did my DEX in 11/07 and did it again in 11/10. The fluid that drained out looked exactly the same as what went in 3.3 years ago.
    Mar 2007
    31
    2,618
    And Sub still has no problems with his HG's
    Maintenance and fluid changes can make a world of difference. It can be the difference between replacing head gaskets, or an entire engine, and not doing anything at all to it-
    ThumperPup's Avatar
    Mar 2009
    37
    7,696
    awesome thanks guys this helps me to decide and all better gona stick with the Dex this way also in case i ever go to a dealer for work or if i forget and slips my mind to tell the shop not to use dex cause i have green then they mix green with dex and ill be screwed
    so this helps and all
    another question was Dex just designed to last longer ? what is it that makes it called Dex Cool is it designed to run cooler also question or is that just the name they slapped on it question
    mhamilton is offline Cadillac Owners Connoisseur
    Automobile(s): 2006 XJ, 2000 Eldorado ESC--total loss :(
    Aug 2009
    North Carolina
    1,180
    I believe it was mostly for the 5 year/100k mile change intervals. It won't cool the engine any differently than the old green. Dex came out in the mid '90s when the engines were just about all running the 100k mile platinum spark plugs. So with the Dexcool, GM could claim "no scheduled maintenance for 100k miles..."
    With the green stuff GM spec'd changes every 2 years or approx 30k miles.
    I do my green coolant every autumn, and also the Eldo I change the Dex every year (overkill, but it was probably never changed in the first 7 years...). My cast iron LT1 '96 Chevy had the the Dex done maybe once in its life... but that's apples and oranges.
    Rippy, you're right about the new cars @ 5yr/150k miles. That must have been a recent change from the old 100k mile spec.
  16. #14
    Sep 2007
    Wilmington, NC
    13,986
    yeah i think someone corrected me recently on that... i had said 100k and they told me no 150k ... i felt a bit dumb
  17. Remove Advertisements
