2000 seville SLS engine removal
Results 1 to 6 of 6
Northstar Engines and System Technical Discussion Discussion, 2000 seville SLS engine removal in Cadillac Engine Discussion; Is it at all possible to remove engine from the top instead of dropping the cradle?...
    hoy_boy4g63 is offline Cadillac Owners Member
    Automobile(s): 2000 seville sls
    Jan 2011
    29
    JoeTahoe is offline Cadillac Owners Enthusiast
    Automobile(s): 2001 GMC SLT, Malibu LTZ, 99 STS studded with NP
    Jul 2010
    Central, NY
    48
    502
    Re: 2000 seville SLS engine removal
    welcome to the forum, It is posible too remove from the top but if you have never worked on a northstar powered caddy I would strongly advise taking it from the bottom. There are lots of brackets and very tight areas. I have a lift so it is really easy for me too say take from the bottom. It takes me around 10hrs to have the subframe out of the car and engine on a engine stand. There are some very experinced members on this forum and they will chime in.
    Jan 2011
    29
    thanx, I do not have a lift available to me at the moment, so is there a specific technique to remove from under without a lift or would it be easier to remove from top? and thanx again for the help
    Jul 2010
    Central, NY
    48
    502
    your best bet would be to get a factory service manual and that will show you the procedure. i have a thread down on in this same area on my own car right now so check the pics out.
    maeng9981's Avatar
    Mar 2009
    Dallas, TX
    25
    3,999
    Even without a lift, most people would still prefer dropping the cradle.
    The most popular way (I think) is to lift the front end with an engine hoist while the "disassembled" cradle with engine stays on the ground.
    http://www.cadillacforums.com/forums...-repair-3.html
    There is an example picture in the middle of above thread ^.
    zonie77 is offline Cadillac Owners Connoisseur
    Automobile(s): 94 ETC,97 STS
    Sep 2003
    Arizona
    3,531
    It is easier to drop the cradle using a hoist to lift the body than it is to pull the engine off the cradle.
    Hard to get your head around it but it's true.
  9. Remove Advertisements
