Stuck in the middle??
Results 1 to 2 of 2
Northstar Engines and System Technical Discussion Discussion, Stuck in the middle?? in Cadillac Engine Discussion; I'm currently in the middle of changing a motor mount on a 98 deville concours and I was wondering if ...
    fristim is offline Cadillac Owners Fanatic
    Automobile(s): 98 Concours 212,000 orginal motor,trans
    Jul 2003
    Springfield Mo
    38
    160
    I'm currently in the middle of changing a motor mount on a 98 deville concours and I was wondering if Im doing it right. I've loosened both tranny mount bolts and also the front motor mount bolts and the torque struts and I cant get the motor to "lift" from the body, its almost like its still bolted in. Any help would be great!! Thanks in advance!!
    growe3's Avatar
    growe3 is offline Cadillac Owners Enthusiast
    Automobile(s): 1993 STS and 2004 DTS
    Oct 2003
    Cameron Park, CA
    564
    Re: Stuck in the middle??
    I do not have the answer to your question, but use caution when raising the engine. The clearance at the back of the engine is very tight. If you raise it to much you will damage the heater barrier; it can crack very easily. The closest item, I think, is the hard plastic wire loom casing that can be crammed into the barrier.
    -George
