Dead starter?
Results 1 to 4 of 4
Northstar Engines and System Technical Discussion Discussion, Dead starter? in Cadillac Engine Discussion; Had my battery tested at autzone after it failed to start, bought a new one, popped it in, it started ...
    vincentm's Avatar
    vincentm is offline Cadillac Owners Connoisseur
    Automobile(s): 1997 Cadillac Eldorado ETC
    Aug 2010
    Kennewick WA
    38
    4,873
    Dead starter?
    Had my battery tested at autzone after it failed to start, bought a new one, popped it in, it started once, turned it off, and now it wont start. When I turn the ignition, it clicks once but nothing
    Submariner409's Avatar
    Submariner409 is offline If it won't run, stick on fender vents
    Feb 2006
    MD Eastern Shore, Kent Island
    56,590
    Re: Dead starter?
    Battery and body terminal connectors clean ??
    You would not be the first to find the starter motor positive cable or solenoid hot wire loose at the motor itself - and that's under the intake manifold.
    vincentm's Avatar
    Aug 2010
    Kennewick WA
    38
    4,873
    Had it towed to Bill Mccurly GM here in Pasco, (less than a mile up the street from me), turns out the positive battery bolt on that cable was stripped, along with that I had the sensor for my air intake fixed, it broke when I attempted my hg project. Also had an ac vacuum line fixed that also broke during my hg attempt.
    And as a courtesy they detailed my interior and gave her a thorough wash.
    Sent from my HTC Glacier using Tapatalk
    Old Skool Soldier is offline Cadillac Owners Member
    Jun 2010
    Sault Ste Marie, ON
    28
    87
    Re: Dead starter?
    Sounds like excellent service! I wonder if my Cadillac dealer will do the same for me, I dropped it off yesterday for a new waterpump, alternator, stabalizer link and fuel level sensor ground
  7. Remove Advertisements
