carbonized pistons what does it mean ?
Results 1 to 9 of 9
Northstar Engines and System Technical Discussion Discussion, carbonized pistons what does it mean ? in Cadillac Engine Discussion; ok this might sound dumb since i dont understand it im gona ask just curiouse because the Shop i called ...
    ThumperPup's Avatar
    ThumperPup is offline Cadillac Owners Master
    Automobile(s): not anymore 2007 Lexus ES350
    Mar 2009
    Murray/ Snowbird Utah
    37
    7,688
    just curiouse because the Shop i called to find out if the caddy would be doen in time for my road trip this weekend or if id have to rent a car
    he said that chanses are he wont have it doen untill Monday since i nore him want the job to be rushed
    he also mentioned to me that he spend most of yesterday Carbonzing the pistons or something liek that what does this mean exactly
    what is it that he did could someone explain to me in word i could understand thank you
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    57,148
    Re: carbonized pistons what does it mean ?
    During the normal combustion process carbon is formed by petroleum fuels - think of it as a hard deposit of ashes on the bottom of your woodstove. Modern gasolines are formulated to chemically break down carbon deposits in everyday driving. No-lead fuels make the process even easier, and Ethanol is a powerful cleaner.
    Carbon deposits which remain on the piston crowns - completely normal - are as hard as diamond - and are an unholy bitch to clean off with the engine assembled - you sure don't want to either scratch the piston crown, the cylinder wall, or get abrasive grit down by the piston rings.
    So proper cleaning is tedious.
    vincentm's Avatar
    vincentm is offline Cadillac Owners Connoisseur
    Automobile(s): 1997 Cadillac Eldorado ETC
    Aug 2010
    Kennewick WA
    38
    4,848
    Will a good premium fuel such as Shell's Or Chevron's with Techron clean the deposits over time?
    69
    82,386
    Sub, I can certainly understand the cylinder walls and grit by the rings, but how would scratching the piston crowns hurt anything? Color me confused.
    Feb 2006
    57,148
    I'm a cleanliness freak - scratched piston tops look unprofessional, nothing else.
    I usually put each piston at TDC, do the crown cleanup with a power wire brush, put a ring of oil around the crown and lower the piston down the bore. Any cleaning grit or carbon sticks to the oil left on the cylinder wall so it just wipes out.
    TECHRON will clean or reduce combustion chamber deposits which is why GM recommends Top Tier gasolines. A 20 oz. jug of TECHRON in a fillup of 93 octane every 5,000 miles is a fuel system cleanup, not much else.
    ThumperPup's Avatar
    Mar 2009
    37
    7,688
    cool thanks guys i get it and understand it better now
    thanks sub for explaining like you did
    ThumperPup's Avatar
    Mar 2009
    37
    7,688
    oh also just curiouse with all thats going on and i guess the cabon built up being goen totaly i know i was already getting like avg 25 to 26 mpg on the highway can i look forward to my MPG getting better atleast for a little bit of time ?
    or chances are is 26 gona be the best i will do
    69
    82,386
    26 is about the best you will do. Maybe a tad better under ideal conditions like a good stiff tailwind.
    ThumperPup's Avatar
    Mar 2009
    37
    7,688
    there was one time running on 90 heading to idaho i picked up 32mpg stedy for about 70 miles on Cruise Control
    i thout it was playing games with me but since i only filled up 70 miles ago when i stoped for bathroom break i filled up again and low and behold it relaly only took like 2.2 gallons to fill up
  12. Remove Advertisements
