horsepower
Results 1 to 2 of 2
Northstar Engines and System Technical Discussion Discussion, horsepower in Cadillac Engine Discussion; does anyone know about the +22 hp progressive tuner off of ebay, they say it plugs into the factory harness ...
    da6umpsfinest's Avatar
    da6umpsfinest is offline Cadillac Owners Member
    Apr 2004
    hampton, virginia
    31
    horsepower
    does anyone know about the +22 hp progressive tuner off of ebay, they say it plugs into the factory harness on IAT sensor and it sends a signal to ur ecu. and from there the ecu makes the adjustments for the performance settings.
    JSMeloche is offline Cadillac Owners Fanatic
    Automobile(s): 2005 SRX V6 AWD
    Mar 2004
    429
    Re: horsepower
    I think it works with the MAF just like all the other diode "scam" advertise on ebay. Basicaly they replace the MAF with a static or variable (in this case) resistance so the computer put more or less gas in the cylinder. So you get a rich or lean mix depending on the condition, throtle position, altitude etc...
    My advice is let the carefully developped computer on a 70 000$ car choose the appropriate fuel mixture instead of a 20$ el cheapo variable resistance.
