transmission is kidna ... odd?
Results 1 to 7 of 7
Northstar Engines and System Technical Discussion Discussion, transmission is kidna ... odd? in Cadillac Engine Discussion; Hey all lately ive been noticeing a sort of "stumble" when im driving like when im in cruise and just ...
    capn's Avatar
    capn is offline Cadillac Owners Fanatic
    Automobile(s): 94 Eldorado ETC
    Feb 2004
    NC PM me if your around here
    216
    Hey all
    lately ive been noticeing a sort of "stumble" when im driving like when im in cruise and just driving lightly under 3,000 my car seems to stumble and feel like it just looses power or fall out of engaugement for a split second, like however you would describe a stumble. but what could this be, my local tech told me it may be vacuum leaks with the cruse but i think its more
    CadiJeff's Avatar
    CadiJeff is offline Cadillac Owners Connoisseur
    Automobile(s): 1981 CoupeDeville, 2 1990 Eldorados, 1994ETC ,1992STS
    Feb 2004
    Nerk,Ohio
    36
    1,072
    Re: transmission is kidna ... odd?
    vacume leaks in the cruise can be quite noticeable. I had one in my 88 seville and it would let the car slip 4mph and then speed back up to set speed with a hard accel. It felt worse than it was.
    capn's Avatar
    Feb 2004
    216
    yeah i mean it doesnt really loose speed it just feels like its not accelerating anymore or soemthng, its hard to explain the feeling, like the constant motion is interrupted
    Pjs's Avatar
    Pjs
    Pjs is offline Cadillac Owners Fanatic
    Mar 2004
    Nashville, TN
    367
    My 95 SLS does the same thing. I thought perhaps I was mistaken at first, because it didn't do it all the time. It started right after I had pulled the radiator to replace a cracked tank. It only does it at a light throttle. I paid close attention for a couple of weeks when driving, trying to determine whether it was fuel, electrical or vacuum related. I finally figured out that I have a slight vacuum leak somewhere...I've checked all the vacuum lines and can't seem to find a problem which leads me to believe that my intake has a slight leak in it. Intake gaskets are only $25 at the dealer and definitely worth trying
    capn's Avatar
    Feb 2004
    216
    Quote Originally Posted by Pjs
    im thinking if its a vacuum leak it will be around the TB area, because i did notice some cracks in the plastic housing on top of it so im going to try and superglue those back together and see if thers any difference
    pos2nat is offline Cadillac Owners Member
    Automobile(s): 1993 Seville STS
    Apr 2004
    6
    sounds like torque converter locking up and disengaging, normally happens with steady driving between 45-65mph, might also be vacuum leak if it only happens with cruise control on...
    jcdsog is offline Cadillac Owners Member
    Oct 2003
    sc
    40
    24
    mine (94 SLS) does the exact same thing. for almost a year now and still havent figured it out. bought new shift solenoids but havent gotten them put in just yet. also i talked to a cadillac mechanic and he mentioned that it could be the torque converter also. is it difficutl/expensive to replace one of those?
    thanks
  10. Remove Advertisements
