Please help with 94 eldo trans trouble
Results 1 to 4 of 4
Northstar Engines and System Technical Discussion Discussion, Please help with 94 eldo trans trouble in Cadillac Engine Discussion; started when I was merging onto exway, check engine light came on, went into 3rd gear. When I would let ...
    alanhoggard is offline Cadillac Owners Member
    Automobile(s): 1994 eldorado
    Dec 2008
    12
    started when I was merging onto exway, check engine light came on, went into 3rd gear. When I would let off throtte it seemed to slip into neutral until getting back into therottle.
    If i put it 3rd when starting out it would function normally 1-3,
    got p029 code.
    Dropped valve body and replaced shift solenoids, filter and added filter L bracket. Reassembled using correct torque.
    filled with 6 qts.dexron VI. It is a bit low on dipstick. disconnected batt for 20 mins.
    Now, it is doing the same thing as original problem but only goes into 2nd.
    zonie77 is offline Cadillac Owners Connoisseur
    Automobile(s): 94 ETC,97 STS
    Sep 2003
    Arizona
    3,531
    Re: Please help with 94 eldo trans trouble
    The valve body bolts only need 10-12 ft lbs torque (look up the spec). Overtightening can cause a problem.
    Dec 2008
    12
    I torqued them to 96 inch lbs.
    Pete315 is offline Cadillac Owners Fanatic
    Automobile(s): 95 Eldorado
    Feb 2009
    305
    if you're close to Long Island NY and your car is a #9 vin car, I have a sweet shifting used tranny for sale.
  7. Remove Advertisements
