Harmonic balancer torque
Results 1 to 3 of 3
Northstar Engines and System Technical Discussion Discussion, Harmonic balancer torque in Cadillac Engine Discussion; Does anyone know the torque spec for the harmonic balancer and the cam cap bolts?...
    miwise is offline Cadillac Owners Fanatic
    Automobile(s): 1999 Cadillac Seville STS
    Jul 2010
    Lafayette, Louisiana, United S
    39
    448
    tateos's Avatar
    tateos is offline Cadillac Owners Connoisseur
    Automobile(s): 1997 ETC (GAVE TO STEPSON 2011), 2000 DTS (RIP)
    Jul 2007
    FOUNTAIN HILLS, AZ
    60
    1,704
    Re: Harmonic balancer torque
    Quote Originally Posted by miwise View Post
    Harmonic balancer - first be sure the balancer if fully inserted...that is, bottommed out on the oil pump drive; then torque bolt to 37 ft pound, then turn bolt an additional 120 degrees, or in other words, turn bolt so a given spot on the bolt adjacent to one of the three pulley spokes is moved to the next spoke - that will be 120 degrees or 1/3 turn. Before installing the bolt, I put a few drops engine oil on the threads (also crankshaft and the front main seal surface when installing the pulley) - then wiped of as much of the oil off the threads as would come off with a rag...so I left just a light residue of oil as a lubricant.
    68
    82,081
    Please update your profile with your year and model so we know what engine and year you are talking about.
