93 sts w/97 n. s. fuel pump problem
Results 1 to 6 of 6
Northstar Engines and System Technical Discussion Discussion, 93 sts w/97 n. s. fuel pump problem in Cadillac Engine Discussion; I installed a 97 low milage (14,000) N.S. in my 93 sts and I have to wind it up in ...
    chuck jenkins is offline Cadillac Owners Member
    Aug 2004
    16
    I installed a 97 low milage (14,000) N.S. in my 93 sts and I have to wind it up in the mornings to get it to start. It starts good all day but I can hear the fuel pump running all the time. Help
    BeelzeBob's Avatar
    Dec 2002
    Fort Lauderdale, Florida
    52
    9,577
    Re: 93 sts w/97 n. s. fuel pump problem
    Have you checked fuel pressure with a fuel pressure gauge installed on teh schraeder valve fitting on the fuel rail while cranking cold to see if it is maintaining a constant pressure.??
    florida33779's Avatar
    florida33779 is offline Cadillac Owners Member
    Oct 2004
    Ohio
    16
    Did you have any problems with the mass air flow sensor and if so how did you fix it. I have a 94 and just had a 97 motor installed and I have erratic idle problems I hear there is a fix but nobody can say where to get it.
    Aug 2004
    16
    I used the 93 throttle body (with no maf) with a spacer on the 97 intake. All 93 wiring harness and transmission. The 97 engine is a 275 hp engine but I can't see much difference in performance. I have not checked the fuel pressure yet. I need to buy a gauge and check it.
    Aug 2004
    16
    Quote Originally Posted by chuck jenkins
    Hey florida33779 I'm florida33037 key largo. Where are you?
    Oct 2004
    Ohio
    16
    I was in New Port Richey Florida but now I'm up in Ohio. I'm sure going to miss the nice Florida winters.
  9. Remove Advertisements
