will a 94 water pump cover fit on a 95?
Results 1 to 2 of 2
Northstar Engines and System Technical Discussion Discussion, will a 94 water pump cover fit on a 95? in Cadillac Engine Discussion; Just want to know if the water pump cover I took off my 94 STS will fit on my 95? ...
    Pete315 is offline Cadillac Owners Fanatic
    Automobile(s): 95 Eldorado
    Feb 2009
    305
    Just want to know if the water pump cover I took off my 94 STS will fit on my 95? Reason why I'm doing this is because my 95 Eldorado has a very slow drip of antifreeze where thermostat housing mounts to water pump cover. When I try to tighten the thermostat bolts, it feels like the bolts holes are about to be stripped. I don't think I'm able to properly torque down the 2 bolts. I had no antifreeze leaks from this 94 cover at all. Also, when I removed 94 cover, it looked like there was no O-Ring in cover. Look like someone used only black RTV. Should I get a new O-Ring or should I just use the black RTV?
    68
    81,889
    Re: will a 94 water pump cover fit on a 95?
    It should fit. Get the proper O ring seal. Someone cheaped out and bandaided it with RTV.
