Setting timing on 1999 STS after HG repair
Results 1 to 10 of 10
Northstar Engines and System Technical Discussion Discussion, Setting timing on 1999 STS after HG repair in Cadillac Engine Discussion; Does anyone have any diagrams or photos for this? Idk which direction to point everything when I'm reinstalling the timing ...
    mwise101 is offline Cadillac Owners Member
    Automobile(s): 1999 Seville STS
    Jun 2010
    39
    62
    Does anyone have any diagrams or photos for this? Idk which direction to point everything when I'm reinstalling the timing chains. Any help is appreciated and welcome. I've read several posts but i'm not sure that I understand what they are saying. I don't know where the markings are on the sprockets and I don't know which direction they should point. I wish it were as easy as a lexus engine, line up the marks with the mark on the belt. Please help. :-)
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    55,529
    Re: Setting timing on 1999 Seville STS after HG repair
    use this...........
    Remember that the harmonic balancer bolt torque is what drives the oil pump - it MUST be torqued to specs.
    tateos's Avatar
    tateos is offline Cadillac Owners Connoisseur
    Automobile(s): 1997 ETC (GAVE TO STEPSON 2011), 2000 DTS (RIP)
    Jul 2007
    FOUNTAIN HILLS, AZ
    60
    1,704
    Good job Sub.
    Personally, I think this is the easiest OHC engine to time that I have ever seen.
    Torque the damper bolt to 37 ft. pounds, then turn it an additional 120 degrees = 1/3 of a turn = one spoke of the damper pulley.
  5. #4
    stoveguyy is offline Cadillac Owners Connoisseur
    Automobile(s): 03 STS
    Aug 2007
    mpls mn
    2,528
    this is the left bank side
  6. #5
    trublu's Avatar
    trublu is offline Cadillac Owners Member
    Mar 2010
    Washington,DC
    16
    Hey Sub, you know any quality shops in MD that do HG repairs? I have a 99 STS with a blown HG, cant find anyone who does insert or studs! Please help!!!!
  7. #6
    Feb 2006
    55,529
    Nope, not around here - get in touch with CF member ewill3rd at Lindsay Cadillac in Alexandria.
    Either PM him through this Forum or call Luke in Parts at Lindsay (he's a terrific parts man who can find stuff no one else can.......)
    (I just saw your other post about the same thing............
  8. #7
    miwise is offline Cadillac Owners Fanatic
    Automobile(s): 1999 Cadillac Seville STS
    Jul 2010
    Lafayette, Louisiana, United S
    39
    448
    Thanks for the replies. The pictures are very helpful!
  9. #8
    southernmex is offline Cadillac Owners Member
    Automobile(s): seville
    Oct 2013
    10
    I do have a question..does anyone knows if the right side camshaf position of the seville 1999 would be the same as the left side.if some body got some pictures would be nice.
  10. #9
    Feb 2006
    55,529
    Here's the Northstar timing diagram. In SOME engines the RE stamping is moved in relation to the timing dot. Use the dots, not the characters.
  11. #10
    Oct 2013
    10
    Re: Setting timing on 1999 STS after HG repair
    Thanks a lot submarine.
  12. Remove Advertisements
