1997 to 2000 engine swap
Results 1 to 3 of 3
Northstar Engines and System Technical Discussion Discussion, 1997 to 2000 engine swap in Cadillac Engine Discussion; What would be involved in converting the 2000 engine to run in the 97. As I understand it the ignition ...
    CadiJeff's Avatar
    CadiJeff is offline Cadillac Owners Connoisseur
    Automobile(s): 1981 CoupeDeville, 2 1990 Eldorados, 1994ETC ,1992STS
    Feb 2004
    Nerk,Ohio
    36
    1,072
    What would be involved in converting the 2000 engine to run in the 97. As I understand it the ignition system is different, is the fuel injection the same or would that have to be swapped to?
    BeelzeBob's Avatar
    Dec 2002
    Fort Lauderdale, Florida
    52
    9,577
    Re: 1997 to 2000 engine swap
    You don't even want to consider it.
    The 2000 engine is very different from the earlier engines. Even the reluctor wheel pattern on the crank and the crank sensor location in the block is different. Nothing in the control system is compatible. Forget it.
    It would be easier and cheaper to just buy a 2000 model year car with the engine already installed and running.....LOL.
    CadiJeff's Avatar
    Feb 2004
    Nerk,Ohio
    36
    1,072
    thanks that is what I thought
