head dowels
Results 1 to 5 of 5
Northstar Engines and System Technical Discussion Discussion, head dowels in Cadillac Engine Discussion; I know this has been addressed before, but I didn't note it at the time, nor can I find it ...
    Harry Yarnell is offline Cadillac Owners Enthusiast
    Automobile(s): 2005 XLR, '96 eldo,'95 eldo,' 89 eldo,'78 eldo,'11CTS-V
    Dec 2004
    perryman, MD
    73
    861
    head dowels
    I know this has been addressed before, but I didn't note it at the time, nor can I find it in the FAQ.
    What's the best way to remove the four head dowels/pins from the block?
    tateos's Avatar
    tateos is offline Cadillac Owners Connoisseur
    Automobile(s): 1997 ETC (GAVE TO STEPSON 2011), 2000 DTS (RIP)
    Jul 2007
    FOUNTAIN HILLS, AZ
    60
    1,704
    Re: head dowels
    I don't know if it's the best way, but what I did, and it worked for me, is:
    I inserted a bolt that fit snugly, but not too tight, in the dowel, so it wouldn't collapse; I actually used an old wheel stud I had laying around. Then, I clamped down on the outside of the dowel with 10" round jaw vice grip pliers, and turned, tapped, and pried, until the dowels came out. I put a putty knife against the deck (the block surface) to protect it, when I pried between it and the vice grips. I marred up and knurled the outer surface of the dowels somewhat - I ground down the raised portions on my bench grinder. I could have bought new dowels at the dealer, but just didn't bother. I inverted the dowels and inserted the previously "up" side down, into the block, just in case they were a little hard to insert due to the vice grip jaw marks...but they went in just fine. This left the fairly pristine side of the dowel on top, for the heads to drop down onto, which they did - perfectly. If you are using Jake's studs, you can discard the dowels - the appropriate studs already have the dowel machines in
    edb150 is offline Cadillac Owners Member
    Automobile(s): Many! I currently own & operate MIDWEST CADILLAC REPAIR
    Nov 2009
    Palatine, Illinois
    51
    96
    Re: head dowels
    Heres what i do. I have a bushing that fits around the dowel snugly(same height). I put a hose clamp around that so it does not split. I have a set of short extractors( about an inch long) that i put inside the dowel.The extractors have a hex for a socket which I break loose by hand with a ratchet and then an impact to spin it out while prying on it with a flatblade screwdriver. I clean them up on a grinder and also invert them. They are around 5.00 at the dealer .The bushing is an old starter bushing.once its out I usually hold the dowel with a vise grip and tighten the extractor which twists it out of the dowel. Did 4 today and saved them all
    69
    82,188
    Re: head dowels
    Another method I saw posted here.
    Insert an appropriate sized threaded rod and weld it to the dowel. Drop a larger diameter piece of pipe over the rod. Now put a washer and a nut on the rod and tighten it down, pulling the dowel. It should not take more than a spot weld or two and you will obviously want to cover the head to prevent any platter.
    Dec 2004
    perryman, MD
    73
    861
    Re: head dowels
    Absolutely slick! Ranger's post was a joy to try. And succeed. Had all four out in 15 minutes
  8. Remove Advertisements
