Results 1 to 3 of 3
Thread: Can't Figure Out How To Set IPC Overides
    Aug 2004
    New Jersey
    41
    21
    Question Can't Figure Out How To Set IPC Overides
    I have a 2000 Eldorado VIN Y. I read a thread a while back where you addressed this issue but in a '96. I am desperately trying to find out if the values you had listed for '96 are the same for 2000. If so, how do you set the value permanently. I can change the value to the right with the passenger warmer/cooler buttons, but once I leave the screen it goes back to the original value. I am specifically trying to change the Option E settings for the display to add coolant temperature, RPM, and vehicle speed. Can't find anyone else on the board who knows anything about it.
    elwesso's Avatar
    elwesso is offline Cadillac Owners Master
    Automobile(s): 2005 CTS-V, 1994 Infiniti Q45
    Jan 2003
    Indiana
    7,661
    Re: Can't Figure Out How To Set IPC Overides
    Moving this to the Northstar section...
    LuborK is offline Cadillac Owners Fanatic
    Automobile(s): none :-(
    Nov 2003
    Prague, CZ
    41
    282
    I would also appresiate to have some more info how to set 98+ IPC overrides.
  • You may not post replies
