NEED HELP TODAY, Can't get tranny out
Results 1 to 8 of 8
Northstar Engines and System Technical Discussion Discussion, NEED HELP TODAY, Can't get tranny out in Cadillac Engine Discussion; In our 94 we followed almost all of the directions in the shop manual (except for removing the manual neutral ...
    bigds01 is offline Cadillac Owners Fanatic
    Automobile(s): 1994 Seville SLS
    Nov 2009
    137
    In our 94 we followed almost all of the directions in the shop manual (except for removing the manual neutral thing). The cradle is free, but the transmission and engine won't seperate.
    What could I have possibly missed? We really need to get it out today. I took off the two side mounts, the three bolts on the bottom (driver side), the upper bell housing bolts (driver side), the electrical on the passenger side.
    Is this something where I need to put a pry bar in to separate them? Did I miss a bolt somewhere?
    When I say the carriage is free, I mean one of my dumbass team members removed all 6 bolts, so I now know it is free.
    Ranger is online now Cadillac Owners Member
    68
    81,764
    Re: NEED HELP TODAY, Can't get tranny out
    Nov 2009
    137
    I can really use some advice. The other post (which I posted on), didn't tell me how to actually solve the problem.
    1996p71 is offline Cadillac Owners Member
    Nov 2005
    48
    I just did this yesterday did you remove the torque converter to flywhel bolts
    Nov 2009
    137
    Quote Originally Posted by 1996p71 View Post
    Are you referring to the four bolts? Got those out yesterday.
    Nov 2005
    48
    I know the starter housing gets in the way and you have to pry it a little there is the mounts you have to remove too is it loose at all from the engine
    cl1986's Avatar
    cl1986 is offline Cadillac Owners Connoisseur
    Automobile(s): 94 Eldorado, 94 SLS got crushed
    Jun 2003
    South Dakota
    38
    1,485
    mine both came apart like a SOB but ya both times the starter was one of the issues, remove the starter for sure....
    just one more reason i say to drop both out instead of leaving the engine hanging.
    Krashed989's Avatar
    Krashed989 is offline Cadillac Owners Connoisseur
    Automobile(s): 94 Eldorado, and a 99 ETC
    Sep 2004
    Hilo, Hawaii
    29
    3,887
    Yes, you forgot something. Carefully look in between the rear bank of the engine and the trans, make sure that all connecting points are disconnected. I made this mistake before and I tried to pry on the bellhousing. I would NOT recommend prying on it, unless it's a very gentle thing to help it separate. If it is hard to separate, there is something keeping it from separating and by prying you could break the bellhousing.
  11. Remove Advertisements
