Mysterious tube coming out of transmission, currently plugged.
Results 1 to 3 of 3
Northstar Engines and System Technical Discussion Discussion, Mysterious tube coming out of transmission, currently plugged. in Cadillac Engine Discussion; Hi Everyone, I had a 6 months hiatus installing a replacement front cylinder head in my 99 STS and just ...
    YueIBM is offline Cadillac Owners Member
    Automobile(s): 1999 Seville STS 226,000 miles, XC90 V8
    Dec 2009
    Ann Arbor, MI
    19
    QuestionMysterious tube coming out of transmission, currently plugged.
    Hi Everyone,
    I had a 6 months hiatus installing a replacement front cylinder head in my 99 STS and just found some time to start the project back up two weeks ago (engine-in-car)...
    I found a tube coming out the top of the transmission that doesn't do anything while tightening down the crossover bolts that I had to loosen to squeeze in a new front head to water crossover gasket.
    The tube is pictured below, with a metallic plug at the end and a plastic clip/bracket around the metallic plug. Is this how it's supposed to be?
    THANKS!!!
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    56,885
    Re: Mysterious tube coming out of transmission, currently plugged.
    That's the transmission vent. The metal cap wiggles - it's a vent - clips right there at the throttle cable bracket - so it pretty much sticks straight up from the transmission case. If the plastic clip is broken, use a black wire tie.
    Look real hard in this pic...........click to enlarge. Just to the right of the top run of the purge line, next to the throttle cables.
    Dec 2009
    Ann Arbor, MI
    19
    SmileRe: Mysterious tube coming out of transmission, currently plugged.
    Wow. Thank you submariner409! I even looked through the FSM and couldn't find it!
    Looks like you capped off the airbox resonator - how do you like it?
    Thanks again for your help! Have a great weekend!
