Engine removal - can't get engine separated from transmission
Results 1 to 7 of 7
Northstar Engines and System Technical Discussion Discussion, Engine removal - can't get engine separated from transmission in Cadillac Engine Discussion; I am unable to get the engine separated from the trans. on a '97 STS - I haven't had this ...
    KHE
    KHE is offline Cadillac Owners Member
    I am unable to get the engine separated from the trans. on a '97 STS - I haven't had this problem in the past. Before, I just lifted the engine slightly with an engine hoist and jiggled it sideways and it separated. I removed the front motor mount to see if that would help but it didn't. There's no good place to pry either. Does anyone have any tips or tricks? I sprayed penetrating oil along the seam last night to see if that would help. Thanks!
    tateos's Avatar
    tateos is offline Cadillac Owners Connoisseur
    Automobile(s): 1997 ETC (GAVE TO STEPSON 2011), 2000 DTS (RIP)
    Jul 2007
    FOUNTAIN HILLS, AZ
    60
    1,704
    Re: Engine removal - can't get engine separated from transmission
    I had this problem too...and I was the problem. Stupid me, I thought the flywheel was held onto the torque converter with 3 bolts, like I have always seen before. Nope - it's 4 bolts! Not sure if that is your problem, but I mention it, just in case.
    KHE
    Nope - I removed 4 bolts from the flywheel. I have never had one that was so stubborn. Even though I followed the service manual steps to the letter, I'm going to check to see if I missed a bracket underneath. It just seems too locked together to be corrosion in the dowels.
    KHE
    The engine is out! The problem was a bolt fastening the passenger rear engine to transmission support. Once that was removed, the engine separated from the trans. without incident.
    bigds01 is offline Cadillac Owners Fanatic
    Automobile(s): 1994 Seville SLS
    Nov 2009
    137
    Quote Originally Posted by KHE View Post
    Where is that support? How did you get the oil cooler line off the back of the transmission?
    cl1986's Avatar
    cl1986 is offline Cadillac Owners Connoisseur
    Automobile(s): 94 Eldorado, 94 SLS got crushed
    Jun 2003
    South Dakota
    38
    1,485
    Quote Originally Posted by bigds01 View Post
    LOL, that line didnt come off either of my trannies, i tried on one but it started to buckle so i quit. You have to rotate the line along with the wrech i believe, not sure why its so stubborn
    KHE
    The bracket was from the rear head to the transaxle. One bolt at the top. I missed it when I disconnected everything and it kept the engine from separating from the transaxle.
    I removed the engine from the topside so I did not need to mess with the line in question on the transaxle.
  10. Remove Advertisements
