Renting engine mount?
Results 1 to 15 of 15
Northstar Engines and System Technical Discussion Discussion, Renting engine mount? in Cadillac Engine Discussion; I need to get the engine mount tool to pull the tranny next week. Anybody know if autozone or their ...
    bigds01 is offline Cadillac Owners Fanatic
    Automobile(s): 1994 Seville SLS
    Nov 2009
    137
    I need to get the engine mount tool to pull the tranny next week. Anybody know if autozone or their ilk rent them?
    tateos's Avatar
    tateos is offline Cadillac Owners Connoisseur
    Automobile(s): 1997 ETC (GAVE TO STEPSON 2011), 2000 DTS (RIP)
    Jul 2007
    FOUNTAIN HILLS, AZ
    60
    1,704
    Re: Renting engine mount?
    What is it - never heard of an engine mount tool?
    cl1986's Avatar
    cl1986 is offline Cadillac Owners Connoisseur
    Automobile(s): 94 Eldorado, 94 SLS got crushed
    Jun 2003
    South Dakota
    38
    1,485
    i think he means the setup to hold the engine while lowering the tranny...
    dont think you can rent that, it comes with an overhead hoist......meanwhile the car is on another hoist
    tateos's Avatar
    Jul 2007
    FOUNTAIN HILLS, AZ
    60
    1,704
    Oh - thanks - that's easy - just drop the whole cradle!
    Nov 2009
    137
    So i have an overhead hoist. Is the mount something I can build myself?
    Submariner409's Avatar
    Submariner409 is online now If it won't run, stick on fender vents
    Feb 2006
    MD Eastern Shore, Kent Island
    56,618
    It's not a mount: you raise the entire car and then lower the entire drivetrain down and out of the body using a pallet jack or similar.
    OR - get a handful of proper sized/length allthread, some nuts and washers, raise the car and one at a time replace the drivetrain mounting bolts with allthread and nuts/washers. Now disconnect any necessary hoses, lines, electrical harness, brake, and suspension interference and use the nuts to sequentially lower and then tilt the drivetrain cradle.
    Pete315 is offline Cadillac Owners Fanatic
    Automobile(s): 95 Eldorado
    Feb 2009
    305
    maybe you could do what I did years ago when I did a clutch job on my 92 SHO years ago- make a support that leans on the inner fender wells and supports and engine. then disconnect engine from tranny and drop subframe and tranny together as a unit. will save you the headache of disconnecting all the sensors,A/C lines, exhaust. you will need that tool that holds flywheel though.
    69
    82,185
    I've seen one of those here I think. They are commercially available. Google "Engine Hangar".
    arctic_man's Avatar
    arctic_man is offline Cadillac Owners Fanatic
    Automobile(s): 2004 Deville
    Jun 2008
    The Sticks, MN
    27
    266
    Quote Originally Posted by submariner409 View Post
    There was a guide on here somewhere that used that method. Raise the car with one jack, disconnect the mounts, and lower the the drivetrain. You can possibly do it with 2 jacks, but I have never done it so I cannot speak from experience. But to be honest, engine mounts go very often. Mine are bad as well, but I have the dog bones on the top of the engine so it isn't of much concern to me, besides the squeek when driving at low speeds.
    ewill3rd is offline Cadillac Technician
    Automobile(s): none
    Nov 2005
    WOODBRIDGE, VA
    49
    11,051
    He's talking about something like this:
    http://arrc.epnet.com/autoapp/9114/c.../87957115L.gif
    I used to use it all the time to leave the engine in and lower it down to remove the trans.
    You can get a table with the vehicle on a hoist and lower the powertrain out to do something similar.
    We actually still use the support for some jobs, it is easier.
    Not sure where you could find or rent one.
    zonie77 is offline Cadillac Owners Connoisseur
    Automobile(s): 94 ETC,97 STS
    Sep 2003
    Arizona
    3,531
    Harbor Freight has an engine support that spans the engine compartment and can hold the engine up from the top. I think the are about $50.
    You don't need it though.
    Nov 2009
    137
    Is there a do it yourself engine mount that you can build?
    Sep 2003
    Arizona
    3,531
    Quote Originally Posted by bigds01 View Post
    It's a long bar with some sliding standoffs that spans the engine bay. The standoffs sit on the inner fender edge. Look at the HF website. A pic is worth 100,000,000 words! ( You can quote me on that! )
  16. #14
    Nov 2009
    137
    Hate to ask a silly question, but which Harbor Freight.
  17. #15
    cl1986's Avatar
    Jun 2003
    South Dakota
    38
    1,485
  18. Remove Advertisements
