Northstar headgasket job did I f up?
Results 1 to 11 of 11
Northstar Engines and System Technical Discussion Discussion, Northstar headgasket job did I f up? in Cadillac Engine Discussion; I wire brushed the head for like a good 2 minutes to get some gasket material off did I mess ...
    1996p71 is offline Cadillac Owners Member
    Nov 2005
    48
    I wire brushed the head for like a good 2 minutes to get some gasket material off did I mess up the block
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    55,910
    Re: Northstar headgasket job did I f up?
    NEVER wire brush an aluminum head. If you can see any pattern or scratching on the head surface you now need to take them to an automotive machine shop and get an educated statement on whether you need a slight cut taken on the head. The spark plug hole threads need to be carefully cleaned with mineral spirits, a twisted brush, and shop air. The head bolt holes need to be brushed out.
    If you wire brushed the block deck, then unless every coolant hole was plugged with rags, the block needs to be flushed out and cleaned. Any gasket material in the cooling system, cylinders or chaincase will play hell with the rest of the engine. Assuming that you're either inserting or studding the block, that job needs to be surgically clean also.
    Nov 2005
    48
    From what I can tell it doesn't look bad there's no deep marks or anything everything is smooth and where can I get the stud kit from
    Stingroo's Avatar
    Stingroo is offline Cadillac Owners 10000+ Posts
    Automobile(s): 92 Caprice Wagon LS1/T56 | 1995 Lexus LS400 | Next: 16 MX-5
    Jun 2009
    Port St. Lucie, FL
    26
    18,369
    68
    81,926
    And DO NOT go near those deck and head surfaces with ScotchBrite.
    Nov 2005
    48
    well what does everybody recommend that i can go buy at the store
    97EldoCoupe's Avatar
    97EldoCoupe is offline Cadillac Owners Connoisseur
    Automobile(s): 97 ETC x2, 04 GXP, 04 STS x2, 97 ESC, 99 Deville, 05 SRX
    Mar 2007
    London, Ontario and Winkler MB
    31
    2,618
    Aluminum is a problem. It's soft and easily damaged. If you use a wire brush, special technique has to be used- like Sub said - any dust created is that of the aluminum itself and will damage the rest of the engine. Surgically clean is the correct term to use.
    Personally - I do use a wire brush in a high speed die grinder. One day I'll take a video of how I do it. A drill is too low of a speed and it will dig in and gouge the surface. Gasket scrapers are a no-no because they will also nick/gouge the block / heads no matter how careful you are. The trick is to BARELY touch the surface and keep that brush moving at all times. This is an aluminum block / aluminum head combination (not a bi-metal engine) so surface smoothness is not AS picky. Once you have different expansion rates, like that of the 4.x series engines with aluminum/iron combination components, you have to have the correct RA on the surface so the gasket won't wear out too quickly from the constant scrubbing.
    One note about a wire brush spinning at above 20,000 rpms - unless you're tough and can handle it when one of those wires shoots up one of your nostrils (safety glasses or face shield an absolute MUST!!) don't even attempt this. And a drill IS too slow. A new wire wheel will be too rough on the surface- it needs to be broken in first on other parts.
    No Scotchbrite - as Ranger said.
    Surface conditioning discs may be OK but no matter what you use, but 3 keys are:
    1) EVEN cleaning and no gouging
    2) Be careful with that aluminum dust- where it goes- it can destroy your engine
    3) Cleanliness
    If you're nervous about this take it to a machine shop and have the heads milled. Very little material can be removed.
    ejguillot's Avatar
    ejguillot is offline Cadillac Owners Enthusiast
    Automobile(s): 2000 Seville STS
    Jul 2006
    Tampa FL
    42
    985
    Here's how I cleaned the gasket material off my heads and block when I installed the stud kit: with Ford/Motorcraft Metal Surface Cleaner and a PLASTIC scraper. Worked like a charm and no risk to the head/block surfaces.
    Here is Ford's statement on cleaning gasket material off aluminum blocks and heads on ANY Ford engine (from Ford TSB):
    WARNING UNDER NO CIRCUMSTANCES ARE ANY ALUMINUM GASKET SURFACES TO BE CLEANED USING RAZOR BLADES, ROTARY ABRASIVE DEVICES INCLUDING ROLOC AND 3M BRANDED SCOTCHBRITE PRODUCTS, ROTARY WIRE BRUSHES, SINGLE HANDLED WIRE BRUSHES, HAND ABRASIVE SUCH AS SANDPAPER OR EMERY CLOTH, OR ANY CARBON STEEL BLADE. THESE TOOLS ARE PROVEN TO CUT AND DAMAGE ALUMINUM AND WILL DISRUPT THE POLISHED FINISH. ABRASIVE PARTICLES ARE ALSO SUSCEPTIBLE TO ENTERING THE ENGINE CAVITIES AND MAY CAUSE INTERNAL ENGINE DAMAGE. THE ONLY TOOLS ACCEPTABLE ARE PLASTIC AND WOOD SCRAPERS COMBINED WITH USE OF MOTORCRAFT METAL SURFACE CLEANER, F4AZ-19A536-RA, OR EQUIVALENT SOLVENT.
    If it's good enough for Ford (who arguably had the better DOHC V8 design), it's good enough for a Northstar.
    stoveguyy is offline Cadillac Owners Connoisseur
    Automobile(s): 03 STS
    Aug 2007
    mpls mn
    2,528
    i used some spray gasket remover. permalock? makes it. at most auto parts stores. and a plastic scraper on the heads. no metal.
    cl1986's Avatar
    cl1986 is offline Cadillac Owners Connoisseur
    Automobile(s): 94 Eldorado, 94 SLS got crushed
    Jun 2003
    South Dakota
    38
    1,485
    i used a razor blade, works great and cleans up just like when you use one on window glass, no nicking or anything but totally clean
    tateos's Avatar
    tateos is offline Cadillac Owners Connoisseur
    Automobile(s): 1997 ETC (GAVE TO STEPSON 2011), 2000 DTS (RIP)
    Jul 2007
    FOUNTAIN HILLS, AZ
    60
    1,704
    Quote Originally Posted by cl1986 View Post
    Right - I usually round the two ends off to avoid any chance of leaving any scratches or gouges.
  14. Remove Advertisements
