error codes
Results 1 to 4 of 4
Northstar Engines and System Technical Discussion Discussion, error codes in Cadillac Engine Discussion; Is there someone out there that could help? I was looking thru my diagnostics and I'm getting an error code ...
    marti4337's Avatar
    marti4337 is offline Cadillac Owners Member
    Aug 2004
    connecticut
    8
    Questionerror codes
    Is there someone out there that could help? I was looking thru my diagnostics and I'm getting an error code of PO39 History,and code SO 44. does anyone know what these mean? Is there any reference material where I could get this kind of info? By the by, got the codes both with the car running and shut off. Any help would be greatly appreciated !!!!!!
    STS-Guy is offline Cadillac Owners Member
    Aug 2004
    15
    Re: error codes
    Hi
    PO39 code is listed as Torquye Converter Clutch Engagement, Problem in 4th gear. This comes out of a Chilton Manual but does not list your other code problem.
    jjbuckley is offline Cadillac Owners Fanatic
    Dec 2003
    113
    Re: error codes
    SO 44 Lift/Drive signal fault...RSS problem
    PO 39 That is a torque converter clutch Problem
    Your best bet is to get a set of factory manuals, try Ebay or Helms inc.
    marti4337's Avatar
    Aug 2004
    connecticut
    8
    Re: error codes
    thank's, I was told that considering that it was stored in history, that it was problably a one time code that was not erased by the dealer @ one time or the other (?) either way thanks for the info!!! I am going to clear them and see if they return. I'm guessing that it might have been my fault (by bunny hopping the front end in 2nd !!)
  7. Remove Advertisements
