Damn this monster pump
Results 1 to 2 of 2
Northstar Engines and System Technical Discussion Discussion, Damn this monster pump in Cadillac Engine Discussion; Well I wish I would have known I have one of the biggest fuel pumps in the Norhtstar family. I ...
    upnout is offline Cadillac Owners Member
    Automobile(s): 1996 SLS
    Apr 2010
    3
    ExclamationDamn this monster pump
    Well I wish I would have known I have one of the biggest fuel pumps in the Norhtstar family. I did some research and found out the others years and vins that are interchangeable with an E8785 or aka 6443546. This site helped me if anybody needs this info: efuelpumps,com
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    56,244
    Re: Damn this monster pump
    You might also try www.rockauto.com, surf through adjacent years to bounce part numbers off each other.
    Stop shouting !!!
    Consider that, if the fuel pump itself is bad, give some thought to replacing the whole module - pump, fuel level sender, and tank pressure sensor - as a unit. While you're at it, check the fuel pressure regulator on the fuel rail - that will play hob with injector pressures and rich mixtures.
