Is my fuel pump bad??
Results 1 to 3 of 3
Northstar Engines and System Technical Discussion Discussion, Is my fuel pump bad?? in Cadillac Engine Discussion; OK here is the scoop. I started my car got half a block and my car was stuttering and sputtering ...
    upnout is offline Cadillac Owners Member
    Automobile(s): 1996 SLS
    Apr 2010
    3
    OK here is the scoop. I started my car got half a block and my car was stuttering and sputtering worse than Daffy Duck. My first thoughts were Thufferin Thufataz!....hahaha....then it died a couple of times on my way back to the house. The throttle did nothing pushed to the floor so I pumped it and got it to give me a little acceleration....I poured gas in the TB at the house and WAM! it started up like a champ and died 3 seconds later. Is my Fuel pump shot????
    68
    81,913
    Re: Is my fuel pump bad??
    Sounds like a fuel pump, but the only way to be sure is to put a fuel pressure gauge on the fuel service port on the fuel rail and see what kind of fuel pressure you have. Should be around 45 psi.
    Apr 2010
    3
    I already have the tank out. I'll probably snag one from a junk yard for eighty bucks or less. I'm in a tight squeeze. I failed to mention that I do hear the pump engage except it is a low rumble or growl sound and I've heard and read that is the sign of a bad pump or pump going bad.
