Head Gasket Repair
Page 1 of 2 1 2 LastLast
Results 1 to 15 of 29
Northstar Engines and System Technical Discussion Discussion, Head Gasket Repair in Cadillac Engine Discussion; First of all allow me to introduce myself, my name is Erik im 20 years old and im in love ...
    eghernandez2007 is offline Cadillac Owners Member
    Automobile(s): 1997 Deville
    Mar 2010
    27
    14
    Head Gasket Repair
    First of all allow me to introduce myself, my name is Erik im 20 years old and im in love with Cadillacs.A few months ago i bought a 1997 deville with a blown head gasket for $700. A tech i know who has never had a comeback from timeserting engines ( has time-serted numerous northstars for his own family) helped me out. Anyways today i finally finished everything, since we had the engine out i replaced almost all the seals. So after im done with everything i start it up but i notice the temperature rises pretty fast. Im very concerned about it so my question to you guys is basically what happens as far as coolant temperature and all that other good stuff, there is no SES light. Thanks for the help.
    68
    82,081
    Re: Head Gasket Repair
    I'm not following the question.
    Mar 2010
    27
    14
    Sorry let me clarify, after the inserts are put in and the repair is done. When i start the car the coolant temperature jumps up a lil too fast for me, is that normal?
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    56,263
    Not sure whether you have a gauge or a digital bar readout.............
    The thermostat is set to begin at 188 and be fully open at 206. Fans run in slow with any HVAC function that calls for the A/C compressor to run, including defrost. If A/C is not set, then the fans are controlled by the coolant temp sensor only and will come on in SLOW at 224 degrees and FAST at 236.
    Initial warmup should be fast - the gauge/bars should get to that 12:00/center bar quickly - the system is set up that way. BUT then the gauge/bars should stay steady unless you're in heavy traffic.
    Coolant level should be halfway up in the tank, cold - no higher than that. Another check is the purge line - that small hose which runs from the upper side of the coolant reservoir to the water pump housing nipple (actually a hollow bolt). The purge line constantly pisses a stream of coolant from the water pump discharge to the reservoir in order to purge the coolant of air and gasses in order to prevent corrosion and water pump cavitation from air bubbles. With the engine cold, remove the tank cap and the tank end of the purge line. Hold the end of the purge line in the tank neck. Have an assistant start the engine and check that a stream of coolant flows from the purge line.
    After a few days of level checks the coolant level should stabilize at halfway up in the tank, cold.
    Mar 2010
    27
    14
    Thanks for the response sub, the dash is a digital one but it doesnt have a bar. I have to go by the actual number the IPC says, when it i seen it quickly jumped to about 210 i shut the car off. This was my first major job so im very nervous.
    68
    82,081
    210 is normal operating temperature. I think it will get to about 240 before it will start sending messages.
    Mar 2010
    27
    14
    But at the rate of speed in which the temp was rising i think it wouldve passed 240
    Skiller.'s Avatar
    Skiller. is offline Cadillac Owners Connoisseur
    Automobile(s): NONE
    Sep 2009
    Buffalo, NY
    27
    2,027
    Take it for a drive and get it up to operating temperature if all repairs are done. It's hard to say there's a problem if you haven't tested it yet.
    Mar 2010
    27
    14
    I guess im just paranoid with all the doom and gloom stories i read on here about the HGs
    cl1986's Avatar
    cl1986 is offline Cadillac Owners Connoisseur
    Automobile(s): 94 Eldorado, 94 SLS got crushed
    Jun 2003
    South Dakota
    38
    1,485
    n* temps rise fast, works awesome in winter time, quickest car to warm up that i know off
    Mar 2010
    27
    14
    Quote Originally Posted by cl1986 View Post
    Too fast if you ask me lol
    Skiller.'s Avatar
    Automobile(s): NONE
    Sep 2009
    Buffalo, NY
    27
    2,027
    Quote Originally Posted by eghernandez2007 View Post
    You just had it repaired?! Go enjoy the car!
    Mar 2010
    27
    14
    Quote Originally Posted by Skiller. View Post
    Hopefully i will
  16. #14
    68
    82,081
    The temp should not rise THAT fast. How long does it take to reach 210? Is the purge line clear?
  17. #15
    Mar 2010
    27
    14
    To tell you the truth im not sure and i didnt even bother to check, it was 5 o clock i was ready to go home but i just wanted to make sure it started
  18. Remove Advertisements
