Blown head gaskets but no pulled/stripped bolts?
Page 1 of 3 1 2 3 LastLast
Results 1 to 15 of 32
Northstar Engines and System Technical Discussion Discussion, Blown head gaskets but no pulled/stripped bolts? in Cadillac Engine Discussion; After acquiring a low mileage 98 deville with the head gasket problem, I worked out a deal with my mechanic ...
    Netjive8's Avatar
    Netjive8 is offline Cadillac Owners Fanatic
    Automobile(s): 1996 Cadillac Seville STS, 1998 Cadillac Deville (Base)
    Jan 2009
    Durham, NC
    224
    After acquiring a low mileage 98 deville with the head gasket problem, I worked out a deal with my mechanic to repair it with me supplying the parts. At this point the engine is out of the car and my mechanic says he needs me to buy the replacement head bolts. I had planned on purchasing Jake's stud kit, but my mechanic thinks that it's worth trying to replace the gaskets and the head bolts by themselves. From my reading on this forum I was under the impression that almost, if not every, HG repair required drilling out the holes and inserting or studding the holes. Is it possible that the holes are fine and it's just the gasket that is the problem? If he is somehow able to properly torque the head bolts, will it be a reliable solution? I'm trying not to spend too much on the repair, but I want to make sure that the repair will last. If replacing the head bolts makes no sense, what would be the best way to explain this to my mechanic?
    Krashed989's Avatar
    Krashed989 is offline Cadillac Owners Connoisseur
    Automobile(s): 94 Eldorado, and a 99 ETC
    Sep 2004
    Hilo, Hawaii
    29
    3,887
    Re: Blown head gaskets but no pulled/stripped bolts?
    If it even survives the torquing of the head bolts, I wouldn't give it till its first oil change before the threads let go. You're putting your wallet in the hands of lady luck if you don't drill, tap and insert or stud the block. I wouldn't take a chance like that. Once the head bolts have been removed, the aluminum in the block has already been compromised.
    stoveguyy is offline Cadillac Owners Connoisseur
    Automobile(s): 03 STS
    Aug 2007
    mpls mn
    2,528
    how clean were the threads on the bolts when they came out? were all of them spotless or have some clinging aluminum in the thread grooves? all my bolts were nice and tight when i took them out. my gaskets had failed between several cylinders.
    68
    81,926
    Krashed is right. The threads may pull on initial torque down or may go 10,000 mile later. Given the amount of work and cost, it just good insurance to insert or stud it now.
    Netjive8's Avatar
    Jan 2009
    Durham, NC
    224
    Thanks for the replies, I was pretty sure that it would require inserting or studding, I just wanted to make sure I wasn't missing something. Thanks for the confirmation.
    MiL32T0N3 iNDU2TRi32 is offline Cadillac Owners Member
    Automobile(s): '99 DeVille
    Mar 2010
    24
    7
    As everybody else has said, make sure you get that block studded!! Anytime I hear of anybody taking a NorthStar out of the car I suggest that they have the block studded even when the motor is being pulled for a different repair, its the only way to ensure the repair is sound.
    Thawcko is offline Cadillac Owners Member
    Automobile(s): Northstar
    Feb 2010
    46
    They may not be damaged right now, but all our Northstars had good head-bolts and threads in the block at one time, and then they all went, it is just a matter of time.... Do it once do it right... After seeing how bad these heads go , If someone gave me a Northstar with out any problems I would still pull the motor and re-stud.... Do not let it go back without a proper repair or you will be soon pulling the motor, and The other damage that can be done with coolant getting in the motor, not worth it... I am myself pulling apart a motor that started with heads, now it looks like bearings from the coolant mixing with the oil... Don't Risk it, it will get ya,....
    cl1986's Avatar
    cl1986 is offline Cadillac Owners Connoisseur
    Automobile(s): 94 Eldorado, 94 SLS got crushed
    Jun 2003
    South Dakota
    38
    1,485
    i pulled mine, did the half case seal, and did NOT do head studs or even touch the heads at all or pull the valve covers.
    No worries what so ever. I will never regret not doing it. These engines come out way to easy to go through all that stud work for nothing.
    114k miles now on my 94 eldo, half case at 113k
    I would NEVER pull a good motor without head issues to stud it, NEVER!!
    Mar 2010
    24
    7
    I dont think I have EVER heard someone say pulling a northstar is "way to easy", anyone that I have ever talked to has done alot of when pulling this motor and would rather put their fingers into a blender then do one again. I know I would....
    Feb 2010
    46
    Also a big difference, the heads are pulled... I would never try to re torque the heads without Inserts or studs... Also if pulling the motor on a Northstar that is going back in is that easy, come on over.... Not the hardest motor to pull but not even close to the easiest.... I could not imagine not putting in the extra few hours to stud or insert the motor if I had the heads off and motor out... if this was a motor that had a slight rep of head failure hey you may want to chance it, but this is a Northstar..... Put one for sale and first question you get is have heads been done....
    cl1986's Avatar
    Jun 2003
    South Dakota
    38
    1,485
    my response was to thawcko when he said if someone gave him an engine in working condition that he would go through all the trouble of tearing it down.
    My response was that if a car was given to me and the engine had no issues, i would NOT pull it to stud it just for the fun of it then go through all the stud work for no reason.
    My last cradle was out in 5 hours, if my HG blow, well i will have it out in less than that next time. Thats why im not worried.
    Im pulling my jeep motor next, and that will probralby take 4 hours, most of the time is gettting ready, draining fluids and all that.
    And dropping the cradle really is easy, its just alot of work, not hard work, but work. The only hard part for me was both cars fuel lines, really stubborn.
    Feb 2010
    46
    I agree with that if working don't touch it.... But seeing it is out and heads off.... and got it with head gasket problem at start... Then stud away...
    cl1986's Avatar
    Jun 2003
    South Dakota
    38
    1,485
    uhh...ya obviously....
    if the heads are off.....you would be crazy putting just new head bolts in, that was already stated several posts up
  16. #14
    Feb 2010
    46
    Thats how he started this post, motor out heads off... was just going to buy new bolts...
  17. #15
    cl1986's Avatar
    Jun 2003
    South Dakota
    38
    1,485
    Quote Originally Posted by Thawcko View Post
    correct, as stated several posts ago
    do you know whats going on yet?
  18. Remove Advertisements
